Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-16-2007, 10:22 PM
ned032002's Avatar
ned032002 ned032002 is offline
Can't find where this wire connects to?
So I'm having a bit of an issue, I was running a wire from the engine bay to the center counsel and when I pulled on the wire it was snagged on a plug that may or may not have been plugged in. Now I don't know where it plugs in, I've searched online but as expected I found no results. I also looked in the chiltons but the electrical area is a little useless when you don't know what it does. Help heres a pic if it helps at all. If anyone knows what it goes to please any pictures and detail where it goes would be awesome. Thanks guys in advance.
91 GSX
Old 12-16-2007, 11:52 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Can't find where this wire connects to?
Don't see the pic
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 12-17-2007, 12:47 AM
ned032002's Avatar
Sorry here they are
Old 12-17-2007, 06:50 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Can't help with the 4G63, looks like it might go to some kind sensor. Don't know though
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 12-17-2007, 07:38 PM
ned032002's Avatar
I didn't get a check engine light w/ it not plugged in so idk.
Old 12-17-2007, 10:57 PM
ned032002's Avatar
So in my search as to where this wire connects to, I also found a broken/cut vacuum line without a home. What is this and why does it have a vacuum line below it that is cut/broken?
and here is where the cable goes to from the filter looking thing.
Thanks guys and I still haven't found the wire connector...
Old 12-18-2007, 12:01 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Looks like the cruise control setup.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 12-18-2007, 06:12 AM
ned032002's Avatar
The vacuum line that goes to that cylinder thingy, is that important or no?
Old 12-18-2007, 10:31 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Are you using cruise control? Why is it even in there. Causes issues with throttle opening and stuff. The vacuum line is import if you're using it. I believe that's what it actually uses to suck the piece open/close to move the throttle plate IIRC. It's all needed though yes if using CC.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-18-2007, 03:31 PM
Testiklees
A/C compressor for that connector
Tim
1990 Talon AWD
PTE SCM5031
Old 12-18-2007, 07:48 PM
ned032002's Avatar
Where does the vacuum line go to?
Old 12-18-2007, 08:59 PM
Testiklees
Where i the other end connected to? I took out my cruise out years ago but in my 90 it was in a totally different spot and if i remember there were no vacuum lines for it.
Tim
1990 Talon AWD
PTE SCM5031
Old 12-18-2007, 09:14 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Should be a black box for vacuum control the hose goes to.
2004 Mazda 6i
1997 Tahoe
Old 12-18-2007, 09:32 PM
ned032002's Avatar
Does anyone have a diagram of all the vacuum lines of the 1G?
