Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 12-16-2007, 09:41 PM
Bondageo Bondageo is offline
1997 GMC Sierra K1500 4x4 5.7 L vortec. Front diff won't engage.
Hi, I get nothing from the front diff when i engage the T/C in 4low or 4high. The electronic acuator seems to be working (I took it out and it moves in and out), and the T/C front output spins in the various settings, but nothing else, is there a quick fix or do I pull the diff apart.
Old 12-17-2007, 01:51 PM
Z15's Avatar
Z15 Z15 is offline
Re: 1997 GMC Sierra K1500 4x4 5.7 L vortec. Front diff won't engage.
Have you tried it with the vehicle moving? Don't get mad, I know someone who could not get his (recently acquired) into 4x4 and he was sitting still every time he tried. Just moving the truck allowed the gears mesh. He felt like a JA when I got it to go in right away by moving the truck and shifting it.
Mike
2010 GMC Sierra SLT E. Cab Z71 All Terrain
2009 Cadillac CTS4 3.6L AWD Performance Sedan
Old 12-19-2007, 01:18 AM
No that didn't seem to work, i screwed around for about half an hour and nothing happened. I couldn't hear any sounds coming from the front either.
thanks though, i didn't even think of that
Old 12-19-2007, 10:57 AM
walkerline walkerline is offline
I was talking to a Technician for gmc. and testing a front actuator solenoid on the bench, it may look like it's working fine because there is no pressure against it. that's why it should be check in place.
Maybe try jacking up the front axle, put key in on postion. (but not running) try 4hi in park. if the front actuator locks your front axle. you should be able to turn both your front axle wheels by just turning one with your hand. if it don't engage only one wheel will spin.
