Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-15-2007, 04:31 PM
aukster aukster is offline
Radiator Leaking and 4 wheel drive question
Mechaninc told me the Jeep GC was bad for leaking around the radiators. Where the aluminum and plastic meet. Is this so? I guess I will need to replace it, just trying to find the cheapest one right now. Also, got stuck the other day when it snowed. I felt like I shouldn't have but did. I have the Quadra Trac system. Was going down the road about 20-30 mph and started fishtailing. backed off the gas ans it was ok til I went into a curve and started again and was stuck. I didnt feel like my 4 wheel drive system was working. I put it in 4 low and still couldnt move. I felt like one tire was spinning and that was it. I know they have to go better than that. There wasn't but prob a 1/2 to 1 inch of snow on road. Any suggestions there? Anything I should check ? Thanks for the help
Auk
Old 12-16-2007, 07:12 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Radiator Leaking and 4 wheel drive question
Auk
The leak in this area of the radiator is very common, you can prolly fix it yourself without replacement. Just remove the radiator from the jeep and using a pair of plier (vice grips would be best) squeeze all the tabs around the radiator on both sides.
as for you getting stuck, the quadra-trac system is a very good system for snow and mud - it has it's downfalls the VC tends to fail - but this would increase your winter performance, but would be an annoyance in the summer.
how good is the tread on your tires. in an inch of snow you should not have gotten stuck, I would say either you have very poor (bald) tires on you jeep or you have an internal problem in the Transfer case.
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 12-18-2007, 08:13 AM
Thanks for your reply. I do have good tread on my tires, They new to the point where I have just rotated them. About 7-8,000 miles. So I am figuring a transfer case problem. Will have to take it to get it checked. I was just curious about the Quadra Trac system. I will probably try the radiator leak myself.
