Problems with 97 Grand Am
Hi,
I have a 1997 Grand Am Se 2.4 Twin Cam engine automatic trans. I have had the car for two years the second day I had it after I bought it the engine spun a rod bearing.I went to the dealer and bought a new GM engine half price$$$. Things when ok after I installed the engine until my first winter with the car.I first noticed that when it got really cold the cruise control wouldn't work unless at or above 45mph. Secondly when I let off the engine the Rpm gauge would bounce between 2-3 grand when mph below 60 or above 45. Althought if I shifted into neutral it would stop. lastly I noticed that the Check engine lite will sometimes come on with a P0507 code.IAC right, well I replaced sensor,cleaned throttle body,checked vacuum lines, and electrical connectors. Still having someold problems I don't know what else to do only does this during cold weather . One more thing I also noticed that when slowing down from highway speed the lights and heater motor dim for a second as if the alternator is kicking out.Any help would be useful when the Check Engine lite comes on the traction control stops working. That means winter driving is tought |
Re: Problems with 97 Grand Am
Welcome to AF.
Your cruise isnt suposed to work under 40mphish. On the boucy rpms its hard to say, when was your last tune up ? These dash clusters are kinda flaky anyway. The p0507 is idle higher then expexted... You could have a sticking throtle cable, or you didnt calibrate the IAC, or its port is partialy clogged. On your lights dimming, could be a low battery, bad ground, bad alternator or just being the POS these cars are. Very typical on Grand am's because the stock 100-105 amp alternators are kinda under powered for all the electronics that run. ANd if your traction control kicks out then you should get it scanned with a ABS/Trans capable scan tool. Probly a wheel speed sensor, another typical problem... ![]() Hope that helps.
1999 Grand Am SS 3.4 OHV
Thanks for the help,
Maybe I forgot to mention that when the rpm gauge bounces I can't hear the engine doing any such change,it feels more like the torque converter kicking in and out.If I brake really hard the bouncing stops,I mean when it does this the whole car shutters.I'm thinking the problem is inside the transmission. Secondly I had just tuned the engine that fall new oil,filter,fuel filter,trans filter/fluid,spark plug Etc the total works. I also took the entire throttle body off the intake and cleaned it. Lastly what I ment about the traction control is that on the new GM cars when the Check engine light comes on it puts this feature in limp mode.Little did I know this but read it from another post.But makes since because it works as soon as the light goes out.Funny thing really the light came on today and after about a hour of drivng it went out.I'ved checked everything but run the wiring for bad spots. I normally have good luck with GM products since it's all I buy I guess if I don't figure it out I will wait this this summer when it stops and sell it. Thanks |
