Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-15-2007, 12:36 PM
Jsharp Jsharp is offline
1993 eagle talon ES FWD Non turbo
Im having trouble trying to start it it will start to turn on then die ill try again and it spudders then dies after doin that for awhile it starts,then after driving for about 5 mins the check engine light comes on,it used to flood till i replaced the O2 sensor then it wasnt flooding but still had trouble starting,and theres black smoke from the exhaust i turned this screw by the throttle body cause i was told it would tune the idle alittle but when i did that my car seems to start flooding again, i know where the throttle adjusting screw is and i adjust that some times when my car seems to idle weird..i was told by a mechanic that my temp sensor is missing but i dont know where to get a new one,can anyone help me on any of these problems.and by the throttle body there is a sensor that is supposed to tell the throttle when to stop or something of the sort and its missing too any ideas on where i can get a new one?
Old 12-15-2007, 12:48 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 1993 eagle talon ES FWD Non turbo
What code are you getting from the CEL?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-15-2007, 12:49 PM
man im not good with the whole code thing how do i find out?
Old 12-15-2007, 12:50 PM
Holset powered 420a
Take it to advanceauto and they will scan the codes for free.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-15-2007, 12:51 PM
i tried that they said then cant scan anything unless its a 1996 or newer they said they dont have the connector for the car.
Old 12-15-2007, 02:08 PM
Holset powered 420a
You need to find one that can scan obd1 cars. That CEL should tell you what your problem is.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-17-2007, 05:19 PM
ok do u know of any places that might or do u know where i can get the sensor that goes next to the throttle on the throttle body.
Old 12-18-2007, 07:23 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Isn't there a way of getting the codes w/o the scanner? Or is that only for the OBD2's?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 12-18-2007, 03:36 PM
I dont know right now im tryin to find somewhere to get a throttle sensor and a temp sensor.
Old 12-18-2007, 04:06 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
You use an analog voltmeter to get codes, or a datalogger.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 01-28-2008, 05:23 PM
i got my throttle sensor and temp sensor hooked up ...on another note it has trouble starting..it will turn overbut not start unless i turn it 3or more times then it will start i changed my plugs and plug wires but still wont start right away..WHAT SHOULD I DO.??
Old 01-28-2008, 09:42 PM
92talontsiawd 92talontsiawd is offline
Send a message via AIM to 92talontsiawd
if it cranks over but wont start right away... then the first thing i would check is the fuel pressure, make sure u are getting enough fuel to the mtoor. MAYBE the fuel filter is clogged so it takes awhile to get the right amount of fuel to the motor.. that would be the first thing i would check.. if its not tht then let me know with alil more info. thnx
Old 01-29-2008, 07:06 AM
JoeShmoe's Avatar
PM time.
Old 01-29-2008, 07:49 PM
ok ill look into the fuel filter and let you know thks...
Old 02-25-2008, 06:56 PM
is there an oil pressure sensor/switch that helps make the car start my friends dad said if its bad it could cause a hard start....anyone????
