Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-15-2007, 08:01 AM
twoten twoten is offline
Brake Lights
I need some help. I have a 2005 Crown Vic. This morning, I noticed that my brake lights will not go off, even after the car is turned off. I have checked the brake fluid...there is plenty. Anything else that I could be missing. I thought maybe something in the brake pedal area. Thanks.
Old 12-15-2007, 12:52 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Brake Lights
Sounds like the brake light switch is not completely shut off. It is located where the brake pedal meets the rod going out of the dash to the power booster.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 12-15-2007, 02:13 PM
Re: Brake Lights
Any way to fix it other than replacing it?
Old 12-15-2007, 05:18 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Brake Lights
Try pulling up on the pedal. If lights go out you may be able to adjust it so it turns off. If you can not get the lights to go off, either replace the brake switch ot look at the connector to see if the wires are touching.
