Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-15-2007, 05:35 AM
jjjc600 jjjc600 is offline
tps location
i have a1997 ford explorer and it runs under power but let off throttle it stalls .i was told it could be the throttle position sensor this truck is all new to me raised on chevrolets. wondering where tps is located
Old 12-15-2007, 11:00 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: tps location
Welcome to the forum!
The TPS is located on the throttle body, opposite the throttle cable. There will be 3 wires going to the TPS, a 5V reference, a ground, and an output. If you are familiar with potentiometers, that's all the TPS is. And by the way, GM uses them too.
You can quite easily test the TPS for linearity if you have a multimeter. If you are interested in how, post back and we'll walk you through it.
I'd suggest testing the TPS before shotgunning it out since there are other things that could cause the stalling. You could also have an Idle Air Control that isn't working right, an EGR system that isn't closing the EGR valve fully at no throttle, etc.
-Rod
