Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 12-14-2007, 10:04 PM
Davescort97 Davescort97 is offline
Escort guy
Timing belt replacement
I have a 1.6 E-TECH ll engine in an 05 Aveo. The Chevy dealership told me to have the timing belt inspected at 30k and replaced at 60k. They told me they have had some come in with a broken belt at 62k-76k and since it is an interference engine have had major engine damage. Seems the pistons run into the valves when it goes. I have several questions. Has anyone had a timing belt break? How many miles were on it when it went? How much does the dealer charge to replace the belt? I want to do it myself, but can't find a Haynes manual for it. Are there any publications that would tell about this?
Has anyone replaced it themselves? Thanks in advance!
Old 12-17-2007, 07:57 PM
mikedudley17's Avatar
mikedudley17 mikedudley17 is offline
Send a message via Yahoo to mikedudley17
Re: Timing belt replacement
http://www.aveoclub.net/phpBB2/viewt...ht=timing+belt
http://chevy.mrmax.dp.ua/EN/document...art_kalos.html
this should get u pointed in the right direction.
damn aveos!!!
Old 12-28-2007, 10:47 PM
Escort guy
Thanks Mike! The information was great. Especially the Daewoo labor time on different jobs. Gives me an idea of what the dealer will charge. The post on the Aveo club telling the steps to replace and adjust the belt is very informative. I think I will do the belt myself. Twice as difficult as an Escort, but the Aveo is a little more complicated engine with DOHC's and 4 valves per cylinder. I really appreciate your help. All the best! Dave
Old 12-29-2007, 07:39 PM
your welcome, anything i can do to help.
damn aveos!!!
Old 03-04-2008, 07:44 PM
MsStressed MsStressed is offline
The Aveo has ZERO tolerance, my timing belt broke at 51,000 miles, my mechanic could not change it because of a dealer only tool for the water pump, it is a 5 hour job, went to dealership to have it fixed. $1234.18 to fix it, belt took out 8 valves. They had my car over a week. To have belt simply inspected at shop is roughly 200 bucks, so may as well replace it while they are looking. Good luck.
MsStressed PS i have a good mechanic and he is amazed at the damage to the motor at 25mph when belt broke.
Old 03-04-2008, 07:49 PM
http://www.aveoclub.net/phpBB3/viewt...ht=timing+belt
just an update on this timing belt how to link. the board has been upgraded to a phpbb3 format so the link has been updated accordingly.
damn aveos!!!
Old 03-05-2008, 07:02 PM
rhandwor rhandwor is offline
The J-Kent Moore tool is very expensive. Go to http://www.ebay.co.uk/ type in Draper 31486 This tool runs around 7.85 pound appx. $2.00 per pound.
Royal air mail is twice as expensive around 5.85 pound. Denlors sells them in the U S for $44.00 Always ask for a shipping price to the U S as some try to gouge you. Abbey tools uk will ship to the U S. You can do a yahoo search for the tool number.
From the picture buy the tool. http://www.lasertools.co.uk/ should also have one.
It takes at least a week from the uk to Atlanta. Laser makes two but different sizes. The 1738 is 41mm
The 1737 is for a different engine. If you work on foreign engines a good source.
Do a www.tool bay biz uk search for laser tools.
This is a cheap timing belt adjustment tool. http://www.autopart.com/TOOLS/TOOLSMAIN/tool/T_A876.htm
Old 03-07-2008, 01:18 PM
hayesbcajh hayesbcajh is offline
Had mine replaced at the dealer at 57k. Cost me around $250-$260 with tax. Belt alone from dealer was over $90. I think they charged 2 hours at $75.
Old 03-08-2008, 04:30 AM
leepotter leepotter is offline
Thats not to bad. Did you have them do the water pump why they where in there?
Old 03-08-2008, 06:43 AM
Get a quote small town dealers are about 1/2 the cost of big city dealers.
Old 03-13-2008, 06:23 PM
I did not have the water pump done. What is the issue with the water pump at 60k?
I feel the dealer is a smart choice for this repair. You at least have a guage to use when getting quotes. Any local repair shop I've used charges $75/hour for labor the same as everyone else. Your local guy may get the part cheaper but I'm not sure what that will save you in the end. They all quote hours out of the book.
Old 03-13-2008, 06:45 PM
Only reason I ask about the water pump is that it is driven off the timing belt, and i've heard its good to have it done while they already have it that torn apart. saves alittle bit of money in the long run if ur pump goes out.
Old 03-14-2008, 03:02 PM
If doing the job yourself the 41mm special wrench is close to 1 9/16 =1.5625
41mm =1.61417 one of my fan clutch wrenchs is 1 9/16 you can borrow one free from Advance or Auto Zone. This is worth a try if you are in a jam with it ready to be torn down with no tool.
Old 03-15-2008, 11:29 AM
Fastervw Fastervw is offline
You don't need the special 41mm tool to do it! I just used a piece of heavy 30# picture hanging wire. I slid the wire through the back of the small arm of the tensioner and then just pulled on the wire as I wrapped it around a srew driver. The wire needs to be about 15 inches long. It's easy if you look at it you will figure it out. Make sure you notch on your crank pulley is pointing down and the two cam pulleyes are ligned up horizontally or you will have a lot of sputtering.
Old 10-26-2008, 01:08 PM
toni1595 toni1595 is offline
I did this timing belt replacement and the water pump as well. Took me about a day. Of course first time and made a few mistakes. I used the Alldata site for a tutorial and by the way their information wasn't completely correct. They show a power steering pump where a motor mount is. Not a real big deal, just a little confusing is all. I contacted them and still haven't heard that they changed it or not. I think the rest of the procedure is OK, although they don't give enough detail about the water pump procedure in my opinion. It leaves a few "minor" details out. I think the problem is that the engines vary with the VIN numbers. Probably their procedures are OK for the majority of these engines but there are exceptions to the rule. Again this is my opinion only. I have no concrete evidence to back this up only my own experience. Anyway if anyone here needs some advice, don't hesitate to ask. I can probably be of some assistance. As far as the special tools, all I did was to make the 41mm wrench from a print that I found online. I didn't have the angle torque wrench, I just estimated where 30 and 15 degrees was. My crank pulley hasn't fallen off yet (knock on wood). Happy wrenching, Toni.
