Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 12-14-2007, 04:05 PM
1iwilly 1iwilly is offline
Question is this possible??? need a fix
hello to all
ok my 2000 sportage 2wd 4cyl is acting up check engine light on with 2 codes 1= cam sensor 2= knock sensor replace both reset light
5 minutes later light is back on with the same 2 codes went back to auto parts store i bought the sensors from gave me 2 new sensors again. reset check engine light and and again same 2 codes keep coming back check the wiring harness no problem found check and clean ground but no luck.any body seen or had this kind of issue.????
Old 12-14-2007, 04:43 PM
LMP's Avatar
LMP LMP is offline
Re: is this possible??? need a fix
How does the car behave?
I can figure out this is mind boggling, but after two sets of sensors, I could only think it is either the wiring, or the computer itself, a low probablility but still a possibility. What are the code numbers ? P0326?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 12-14-2007, 05:53 PM
Question Re: is this possible??? need a fix
i can remember the codes # but 1=cam sensor 2nd one knock sensor
the car is sluggish taking off then after 2500 to 3000 rpms it runs fine
when taking off i have to rev high like 1500rpm to take off then it feels like it is chocking and if i let off the accelerator a little bit then i get better pick up
the wiring was check and found nothing broken or burn at idles the engine sounds like it is running on 3 cylinders but compression test shows 110 pounds on all cylinder
Old 12-14-2007, 06:16 PM
LMP's Avatar
LMP LMP is offline
I think you said on your other thread that the timing belt had been changed...however 110 psi ??...ok it is near 8:1 isothermic compression ratio...but would have expected a little more. Were it mine, I'd take a look at the timing belt just to be sure . COUld off timing of cams explain the cam sensor code...? I do not think so...anyway, here is the detail:
www.geocities.com/lmp4203/kiasport/dtc0342.pdf
www.geocities.com/lmp4203/kiasport/dtc0343.pdf
..and for the knock sensor code, : www.geocities.com/lmp4203/kiasport/dtc0326.pdf
..by the way, how did you get the codes read?
Old 12-14-2007, 06:34 PM
Were it mine, I'd take a look at the timing belt just to be sure . Off timing of cams might explain the cam sensor code...
i thought about that but the car starts right up fine now here is my question
when the crank is at tdc mark like it shows on the manual shouldn't the piston be all the way to the top? when i take the spark plug out and i insert a long screw driver in the hole when i turn the crank by hand to bring the number one piston all the way to the top the it doesn't line up at the tdc mark. at the tdc mark the piston is down a little??thanks for your reply
Old 12-14-2007, 08:00 PM
LMP's Avatar
LMP LMP is offline
Good point..I do not have a definite answer for that.
I'm not sure if the mark on the crankshaft is really TDC or if it is simply there to be put in relation with the other 2 marks for setting the cam position...
Old 12-14-2007, 08:32 PM
ok when the exhaust mark on the cam gear is line up with the mark on the backing plate i can also see that the dowel on the cam is at 12 oclock position
but on the intake side the dowel is more like to the right of the 12 oclock position???home this makes sense
Old 12-15-2007, 08:12 AM
LMP's Avatar
LMP LMP is offline
..as long as the marks are all together at same time as shown on drawing, all is OK
Old 12-19-2007, 10:17 PM
kyle95g20 kyle95g20 is offline
grounds. clean the grounds under the kick panel on the passenger side. also clean the grounds under the battery tray. there was a huge tsb on sportages concerning driveability problems and repeat codes directly related to the ecu and sensor grounds.
gone through so many cars i can't keep track. all i know is i have a gsr swap on the floor of the garage that is going in a teal boxy hatch.
Old 12-20-2007, 08:43 AM
LMP's Avatar
LMP LMP is offline
Originally Posted by kyle95g20
... grounds under the battery tray. .
Wow...I do believe that, but I can't believe they did it again: how after 100 years of car making do they still make electrical connections UNDER a battery It happened twice on my Taurus: first a fusible link that hung there and was totally destroyed by acid....it was the feed for the computer! And then a connector just beside the battery: the wire just slipped out of the connector (but just after I pulled on it), totally corroded by acid: it was the feed to the alternator exciter....
I think this is a cue to remember as first on the list ...
