Old 12-14-2007, 09:13 AM
blazinman08 blazinman08 is offline
Question power steering problems
i have an 89 s10 blazer and one day the power steering started leaking and i cant figure out where it is leaking from is it possible to crack a power steering pump help please
Old 12-14-2007, 10:05 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: power steering problems
You need to find where it is leaking first thing.
Pressure leak or sitting still leak?
For a pressure leak.
Clean of old fluid leak and fill it up and start engine and crank wheels right and left and watch for ps fluid to leak out.
For a hard to find leak they make a leak dye kit that may help you.
MT
MT
Old 12-14-2007, 10:24 AM
Question Re: power steering problems
for it to be a pressure leak wouldnt it stop after i shut it off it leaks out from full to empty in prob anout 1 mile so and its coming from underneath the resovior
Old 12-14-2007, 11:54 AM
MT-2500's Avatar
AF - Advisor
If it runs dry in a mile you have a big leak.
Does it also leak with engine off?
Clean it off and look for where the leak is starting to leak.
If you can not see under there a small mirrow may help.
Watch front seal and ps hoses and fittings and around the resovior tank.
Remember a leak will run down so go to the top of the leak.
Good luck
MT
MT
Old 12-14-2007, 12:27 PM
yea it leaks even with the engine off so emm sould it maybe be the seals or hoses
Old 12-14-2007, 12:43 PM
MT-2500's Avatar
AF - Advisor
We can not see it with the key board or pc monitor.
You need to have a good look and see where it is leaking.
If all else fails take some pictures and post back some pictures or run it by a repair shop and have them take a look at it.
Good Luck
MT
MT
Old 12-14-2007, 01:27 PM
and another thing the power steering pump always winds now like its not even getting powersteering fluid
Old 12-14-2007, 02:06 PM
MT-2500's Avatar
AF - Advisor
lOOK AND FIND THE KEAK.
Then we can go from there.
MT
MT
