Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-14-2007, 08:03 AM
hyundaiaccent15 hyundaiaccent15 is offline
Stuttering turbo
When giveing alot of throttle to start boost car stutters for a slight moment then spools and takes off what could be my problem is it just a vacume leake?
Old 12-14-2007, 08:25 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Stuttering turbo
Bad spark plugs could even be the cause.
What make and model? Mods?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-14-2007, 01:59 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Have you done a tune up recently??
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-14-2007, 03:35 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Seconded, do a boost leak test and change your spark plugs and go from there.
First thread and he used the subforums! You get a gold star for the day, welcome to AF.
EDIT: Also might want to check o2 sensor(s) and make sure the MAF sensor is plugged in.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-14-2007, 04:48 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Change the plugs and gap them correctly. The stutter will go away.
95 Talon TSI AWD
97 Eclipse GST
