Old 12-14-2007, 07:37 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Front wheel bearings - '98 K1500 4WD
Is it best to replace the entire hub assembly, or is it possible (using a press) to simply replace the bearings?
I'm getting some noise in the front end while driving, and with 120,000 miles, I don't want to take any chances. I'd rather just get new bearings in there and not have to worry about getting stuck.
thanks
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
Old 12-14-2007, 05:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Front wheel bearings - '98 K1500 4WD
It must be replaced as an assembly. Make sure the noise is the bearing first, they are too expensive for most people to be guessing.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-15-2007, 07:34 AM
Chevy-SS's Avatar
I found a pair of new hubs for cheap money -
http://www.1aauto.com/1A/wheel-beari...HS00009/650372
Are these hubs OK to use?
many thanks
1968 427 Camaro SS
2004 Corvette Coupe
Old 12-29-2007, 10:35 AM
thecackster's Avatar
thecackster thecackster is offline
Send a message via MSN to thecackster
nice, i had that problem around 120000. only the front left went though. It wasn't cheap and neither was the tow. The guy who had it before me must have welded the nuts on. Crazy?
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 12-30-2007, 06:55 PM
Carwhiz Carwhiz is offline
Wheel hubs are not parts you want to go "cheap" on. You get what you pay for....I used cheap one before and it lasted just over a year. had to do all that work again, plus alignment AGAIN! this time i paid the extra few pennies for a "better" one
