Old 12-13-2007, 10:31 PM
forthecubs forthecubs is offline
Power Steering Power Shaft Sheered in half
I have 1996 lumina. The power steering quit working. I replaced the pump. The old pump had sheared the shaft into. I had never seen that before. I replaced the pump with a remanufactured pump. In a week I had the same problem. It sheared the shaft into again. Any ideas what would be causing the shaft to break?
Thanks,
Old 12-14-2007, 04:21 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Power Steering Power Shaft Sheered in half
I don't know but any time you have a catastrophic failure of a pump, you'd want to flush the entire system before putting a new pump on...because whatever the original pump "ate" to jam it up is still in there, plus now shotgunned with debris from the pump failure...your steering rack will be next...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
