Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-13-2007, 09:41 PM
0-60IN2 0-60IN2 is offline
96 headlight help
I need help.....how do I Change the headlights on a 96 GSX? There is one bolt that is extremely hard to get at and stupid.
Old 12-13-2007, 10:10 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: help
You have to take the bumper off. There are 3 you get from behind the headlight and one from the front of the car. Trust me, you cant get the headlight out without taking the whole bumper off. Even if you can get the bolt out you cant get the headlight out.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-13-2007, 10:14 PM
Re: help
How exacly do you take the bumper off....the front liek 8 bolts....and the fdender bolts and the walla?
Old 12-13-2007, 10:24 PM
Holset powered 420a
Re: help
All the bolts under the front, the clips in the front on the top of the mouth part. Clips in the wheel well, and the 2 bolts right above the side markers on the inside. And 2 more clips under the headlights.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-13-2007, 10:25 PM
Re: help
Is it hard to get at everythign? est. time? and are the clipse easily removed and do they break easy?
Old 12-13-2007, 10:28 PM
Holset powered 420a
Re: help
Just find a screw driver that fits them good so you dont strip them out and they are easy. It should take you about an hour or two the first time. I can have mine off in like 10 min tops, but I dont have those 9 screws on the bottom of mine anymore.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-13-2007, 10:30 PM
Re: help
On the bottom? I have screws on the top in the middle of my bumper.
Old 12-13-2007, 10:42 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: help
I told you I am not moving any more of your threads. You can make a new one in the correct spot, or I will continue to lock the misplaced threads. This is clearly an exterior question, put it in that subforum.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Closed Thread
