Old 12-08-2002, 01:34 AM
90cIvIcSiR 90cIvIcSiR is offline
Send a message via AIM to 90cIvIcSiR
Alarm led's
I am trying to change the led's in my wife's car to ultra-violet led's, unfortunatly her alarm only supports 1 led. Is there a way i could wire them to constant, ign. and ground with something in-line to make them flash, and if so....what? please help!
sorry about the crappy pic!
Old 12-08-2002, 10:56 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I am not sure exactly what you want to do
Old 12-08-2002, 04:12 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Simple. Just wire the extra LEDs in parallel off the LED that's already there.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 12-08-2002, 08:23 PM
I know how to do it, but what i am saying is this does not work, because her alarm will only allow there to be 1 l.e.d. on the circuit. I need to find a way to wire them by themselves with a resistor and some sort of flasher relay (kind of like for a blinker) but i don't know how. I could figure it out but don't have the time. So any help???
Old 12-09-2002, 04:22 AM
Cali Guy
Weird, I've never heard of an alram with a voltage sensative LED input/output. Did you try it already? If so, what happened? I have other LEDs tapped into the main on for my alarm, I even changed mine out for a hyper bright blue one, that's less wattage I think. Maybe try a lower voltage LED? Standard for alarm one is usually about 3.6v
hessemer69 on AIM
Old 12-09-2002, 11:58 PM
Question tried it
I tried it.....like this __+__led1__-__+__led2__- but for some reason it overloaded it, I am using 3.7v ultraviolet led's and I have done it on my other car....if you know a better way, let me know!
Old 12-10-2002, 07:09 PM
Audio Guy
you have them in a series confuguration, so it will halve the voltage. It might not be enough to turn either of them on. you should hook up both positives and both negatives together. That way they will get the same voltage, but draw twice the current.
Old 12-10-2002, 08:38 PM
Cali Guy
Pulled the words out of my mouth, that's what I was refering to in my original comment. Hook the + lead of the LED to the + lead of the already working LED, then do the same wit hthe "-" lead, and it should work. Instead of how you showed it, it should look like this:
+ LED1 -
| ____ |
+ LED2 -
See how both positives connect off eachother, and the same with the negatives? (ignore the line that goes left to right above "LED2")
hessemer69 on AIM
Old 12-11-2002, 02:49 PM
if i do that they are reduced in brightness.....like to almost nothing.....I am out of ideas.
Old 12-11-2002, 03:02 PM
Cali Guy
That's odd, if you wire them in parallel, brightness shouldn't be reduced at all, or so slight you wouldn't really even notice if it were.
Are you wiring the positive of the violet LED to the positive of the existing alarm LED? If you do that, and then the negative of the violet to the negative of the existing, neither should reduce in brightness... Does the violet LED have straight wire leads coming off it, or is there a resistor of some sore attached to one of the wires of it? If so, cut it off, then it should work fine. It might help to know what alarm system you have as well.
hessemer69 on AIM
Old 12-11-2002, 03:09 PM
I have an Avital alarm system, and what I did is i replaced the led that was there with a violet one and then I tried both ways described and parallel worked but was very dim, and series didn't work at all. I was just wanting to know if there is some kinda of relay I can just make my own flashing circuit thats is seperate from the alarm that loses power once ign. is +
Car Alarm Repeatedly Going Off AlxBlack17 Taurus | Taurus Wagon 1 03-01-2010 07:48 AM
Unknown alarm system replacing remote Football42008 Engineering/ Technical 6 01-17-2010 11:44 PM
1997 Tercel alarm resets when battery disconnected Simstim Tercel 3 01-10-2010 03:36 PM
auto theft alarm skelou What do you want to know? 0 09-22-2009 12:01 PM
FYI; LED's FreeLz Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 04-08-2001 09:14 PM
