Old 12-13-2007, 08:23 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Just wondering about replacing 1989 TH400 with 1992 4L80e
I may have the opportunity to acquire a 92 K2500HD with the turbo diesel engine and 4L80e tranny. The body is shot, but the drive train is good. I was told that these diesels weren't computerized yet, so the tranny should have it's own computer. I'm wondering how true that is. And if it is, what would be involved to replace the th400 in my 89 K3500 with 454 and 4.10 gears. I do know that the 4L80e is longer than the th400, but both trucks are 4x4 reg cabs with long box and both have 14 bolt full floater diffs, so the drive shaft will be ok. I like driving the K3500, but it goes through fuel so fast it's like someone poked a very large hole in the fuel tank.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 12-14-2007, 11:10 AM
2000CAYukon 2000CAYukon is offline
Re: Just wondering about replacing 1989 TH400 with 1992 4L80e
If it is truely an "e", then it is computer controlled. Not sure what the 1st year for the 4L60E is; however, you can still use it, you will need a controller to make it work.
//2000CAYukon
Old 12-14-2007, 05:06 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Why not put the good body on the diesel truck? You'll get much better MPG with diesel, plus more power.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-16-2007, 07:42 PM
I had a big reply typed up this am but for some reason the web site wouldn't load up. No it wasn't the operator as every other site loaded fine. Anyway, in a nutshell:
The k2500 truck is not a sure thing cause the co-worker just bought a three year old D#@$%e truck from another co-worker which was being sold because it couldn't haul a trailer and k2500 truck owner isn't sure if will haul his trailer, so it may be awhile (months) before I can get it.
I plan on starting the body change over in the spring
I'm sure the torque of the 454 will destroy a stock 4L60e
I thought that all 4L80's were 'e's. I'm pretty sure that a 4L80e from a non-computer controlled diesel will have it's own computer/controller.
Anyway, it sounds like more work than expected. Has anyone tried Thorley tri-y headers, as I have some edelbrocks on my 92 305 but I'm not impressed with the cost vs. value.
