Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-13-2007, 07:59 PM
Rugs Rugs is offline
Intake Manifold 7.4l Engine
I'm planning to replace leaking IM gasket this weekend. Can someone tell me torque setting for lower IM. 1997 Suburban 7.4l.
Thanks.
Rugs
Old 12-13-2007, 08:07 PM
brian 1 brian 1 is offline
Re: Intake Manifold 7.4l Engine
  1. Install the upper intake manifold bolts using the following procedure:
    1. Coat a minimum of 8 threads of the bolts with threadlocking sealant GM P/N 12345493.
      Tighten
      Tighten the bolts in sequence to 8 N·m (72 lb in).
      Re-tighten the bolts in sequence to 14 N·m (10 lb ft).
Old 12-13-2007, 08:08 PM
sorry the picture is so big,dont know how to reduce to normal size.
Old 12-14-2007, 04:59 AM
Good pic of upper intake. Thanks brian 1.
Anyone have lower Intake Manifold bolt torque settings?
Rugs
Old 12-14-2007, 10:23 AM
777stickman 777stickman is offline
1st pass = 22 ft/lb. 2nd pass = 30 ft/lb.
('98) GM service manual (7.4 chapter).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-15-2007, 10:37 AM
Stickman...thanks for the torque setting information.
_______________________________
1997 Suburban 7.4L engine with 160K miles on it. This is number 5 Intake Manifold gasket replacement. The first three IM gasket replacements were done at three different GM garages. A brand new GM lower IM was installed on 3rd repair. I replaced IM gasket 4th time with 136K miles on engine in June 2005. Used Victor Reinz brand IM gasket. Tapped each bolt hole for debris. Installed all new GM IM bolts. Used locktite as per GM service manual. I'm at a loss for permanent fix other then to replace engine or burb.
I'd like to post pictures of IM gasket. Any instructions for posting pics?
Thanks.
Rugs
Old 12-15-2007, 06:43 PM
For posting pic's you have to sign up for a web hosting service such as "photobucket" or something similar.
Also most all the "heavyweights" on here recommend the FelPro gasket sets.
Check out the "DIY intake" link in the Silverado forum. Keep in mind that this forum is for the 5.7 only but has some good tips for all.
57 Chevy 210
