Old 12-13-2007, 10:37 AM
hotrod39 hotrod39 is offline
1990 cherokee door seals
mine leak like crazy, wind noise, is this normal? can it be fixed semi-easily? its noisy when driving down the road
Old 12-13-2007, 11:23 AM
citizen@large's Avatar
citizen@large citizen@large is offline
Re: 1990 cherokee door seals
Sure, It's not all that hard to fix. Just goto-
http://www.quadratec.com/advisor/jee...xj_body.php#4a
Scroll down to 'weatherstrip, door' or 'weatherstrip, liftgate'....
$20 each. Not too bad ehh?
Old 12-13-2007, 12:38 PM
not bad at all, just bought for the doors, is this common, or am i just lucky??
Old 03-07-2008, 10:35 AM
so i changed the door seals and still have the same problem, investigated further and found the door hinge weld are breaking, the visible vertical weld is gone, the horizontal welds appear intact but it seems the door is not correct because of this and it causes the leaks. can this be fixed???
Old 03-07-2008, 06:38 PM
Try here- http://www.go.jeep-xj.info/HowtoDoorHinge.htm
And here- (This has the DaimlerChrysler Corporation Technical Service Bulletin in PDF format) http://www.i-car.com/html_pages/tech.../070102b.shtml
Old 03-08-2008, 09:00 AM
wwwildman wwwildman is offline
My sons 89 was doing the same thing. I took it to the local body shop and $200 later, problem was fixed and it never broke again.
Good luck
