Old 12-13-2007, 06:28 AM
2string 2string is offline
Keep adding Antifreeze
I have to add about every 40 days but I can't find where it's leaking. How do you tell if it's a head gasket? I don't see any in the oil. 4.8L 77,000
2003 Silverado
K&N filter
Borla Exhaust
SSV Trailmasters
Eclipse head unit
Eclipse amps
Dynaudio components
JL Audio sub
Old 12-13-2007, 07:12 AM
jem270's Avatar
jem270 jem270 is offline
Re: Keep adding Antifreeze
How much do you add?
1997 Grand Prix SE, 3.8 (L36), 4T60-E (auto) M13
2002 Grand AM SE1, 3.4 (LA1), 4T45-E (auto) MN5
2003 Silverado LS, 5.3 (LM7), 4L60-E (auto) M30
1988 Ford Bronco EB 5.0 (AOD) manual BW1356 & hubs
Old 12-13-2007, 07:17 AM
It drops down about an inch from the full mark. I don't see it on the ground or anywhere under the hood.
2003 Silverado
K&N filter
Borla Exhaust
SSV Trailmasters
Eclipse head unit
Eclipse amps
Dynaudio components
JL Audio sub
Old 12-13-2007, 09:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Does not sound like a head gasket.
You may have a small coolant leak cold or hot or warm.
Check rad sides and waterpimp seap hole and all hoses rad and heater and around intake gasket and watch borronm of heater core housing and also coolant tank and tank return hose.
And last but not least a bad rad cap will let coolant out.
If GM pink coolant it will leave a little pink stain where it is leaking.
A pressure tester on rad cold and hot amd also watch on warm up or about half warm may show the leak.
Different leaks will leak at different temptures.
I had a rad one time that would pour out a stream at one certain tempt on warm up and not leak at any other tempt.
They make a leak dye for the coolant system.
Helps spot small leaks.
Good Luck and let us know how it goes.
MT
MT
Old 12-13-2007, 10:12 AM
Thanks I will check all areas suggested. Encouraging news that it's probably not a gasket.
2003 Silverado
K&N filter
Borla Exhaust
SSV Trailmasters
Eclipse head unit
Eclipse amps
Dynaudio components
JL Audio sub
Old 12-13-2007, 10:45 AM
muff34 muff34 is offline
Stupid as this may sound,I seen some vehicles for whatever reason that will not stay at the full mark . An inch from full was not a problem, but ya I had keep an eye on things just incase .........lol
Life Is A Highway ,Enjoy The Ride
Old 12-13-2007, 11:49 AM
Interesting I just had a mechenic tell me the same thing. Instead of topping it off I'm going to let it go but keep and eye on it.
2003 Silverado
K&N filter
Borla Exhaust
SSV Trailmasters
Eclipse head unit
Eclipse amps
Dynaudio components
JL Audio sub
Old 12-14-2007, 06:25 AM
i think it's the water pump. Is aftermarket ok and is it a big job? I've done them in older vehicals but not this one.
2003 Silverado
K&N filter
Borla Exhaust
SSV Trailmasters
Eclipse head unit
Eclipse amps
Dynaudio components
JL Audio sub
Old 12-14-2007, 08:41 AM
MT-2500's Avatar
AF - Advisor
Not hard.
Older and newer GM truck v6 and v8 water pump replace are all about the same.
Some have ps and air pumps and ac belt stuff.
Yours may have a seperate AC belt. Check it real close.
I HAVE HAD A LOT OF THEM BREAK.
A couple of hrs should get it.
Check all hoses and belts when you are replacing it.
And a good time to flush coolant system and new thermostat.
Yes aftermarket is OK on water pumps.
But I would go a good brand of brand new not rebuilt with aftermarket water pump.
Have you found water pump coolant seapage at the weap hole?
MT
MT
Old 12-14-2007, 10:17 AM
j cAT j cAT is offline
I have not found any leaks on my sil 1500 5.3 but it is possible that the thermostat housing gasket is leaking. being as you know in a location that is hard to inspect. i found that the gasket is not very thick and it could easily leak. check for leaks after vehicle cools down over night before you start up the next day. as mentioned weeping coolant out the pump vent hole is another area to check especially if the engine runs ok. on my vehicle the only way you can check all this is to remove the air intake ducting. another area observed that was designed poorly is the radiator drain valve . good luck ...........
Old 12-14-2007, 10:22 AM
MT-2500's Avatar
AF - Advisor
On the hard to find leaks the coolant dye leak test kit works good.
MT
MT
Old 12-14-2007, 11:00 AM
[quote=MT-2500]On the hard to find leaks the coolant dye leak test kit works good.
If i can't find leak buy the methods i explained before, i use the pressure test method. this i use not only on coolant but have used to locate and test for leaks on mercruser outdrives before mounting on engine, and after water pump impeller replacement.
Old 12-14-2007, 12:03 PM
MT-2500's Avatar
AF - Advisor
[quote=j cAT]
Pressure test and looking at it is good.
But on the hard to find ones or the ones that leak psrt time or at certain temptures.
The old coolant leak dye will tell you where the hard to find leaks are.
MT
Old 12-14-2007, 05:11 PM
[quote=MT-2500]
yes I have used the dye to find freon leaks but i have never needed this on engine coolant leaks. i guess i'm lucky on that failure.
Old 12-14-2007, 05:42 PM
MT-2500's Avatar
AF - Advisor
[quote=j cAT]
The coolant dye works just like the AC dye test.
Not needed often but on the real hard to find or strange leaks it does help.
Some in intake cover up lines and water pump leaks and hard to get to stuff can be a pain to get to leak and I have had leaks that you would have to drive a few hrs or a day to get them to leak and others that would only leak at a certain tempture.
The dye will show the area of the leak even after it has leaked and dryed up or quit leaking.
MT
MT
