Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-13-2007, 01:53 AM
cheap_jeep88's Avatar
cheap_jeep88 cheap_jeep88 is offline
tranny swap
yes i have a 92 bonneville that i blew the tranny in. i picked up a tranny out of a superchargeded 95 bonneville. i was wondering if that will bolt into my car with few modifications. and i also have a spercharger that i would like to put on my motor it came out of an supercharged bonneville. it was a 94 class 2 supercharger i know i have to change the intake. and maybe the injectors. and pulleys. if here is ayhing else would someone plz tell me. i need the help
Old 01-04-2008, 12:12 AM
Re: tranny swap
bump
Old 01-05-2008, 08:50 PM
Jrs3800 Jrs3800 is offline
Re: tranny swap
The trans from the 95 will have a different pin out arrangement and instead of using a Temp switch the 95 uses a Temp sensor that will also have to be changed out.. Also its will be a 2.97 Gear ratio.... You may have a 2.84 or 3.06..
I would not recommend trying to get the SC components to work on your engines.. In trying to make it all work it may be easier and cheaper to get a Complete Engine/Trans/PCM and wiring harness..
The L27 Tuned Port is a good engine... But the L67 Rods, wrist pins and pistons aren designed with Boost in mind... The L27 internals are not..
I am not saying it can't be done... It can.. But after what I have seen you'd be better off saving for a supercharged car or a complete drop out
