Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 12-12-2007, 09:29 PM
Fastcivic2 Fastcivic2 is offline
Fring order
Hello guys well I think I blow up I decide to change the wires on my 97 Accord and I miss place any one can give the firng order 97 honda Accord pli tanks much
Old 12-12-2007, 10:49 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Fring order
The cylinders start from the timing belt. So with a 4 cylinder Accord, it will look like this when you look straight on from the front of the engine:
*transmission* 4 3 2 1 *timing belt*
On the distributor (of a 4 cylinder); the top Right goes to the #4 cylinder (closest to the distributor), the top Left goes to the #3 cylinder, the bottom Righ goes to the #2 cylinder, and the bottom Left goes to the #1 cylinder. If you do a search on here, in the '88-'91 Civic (4th gen) sub forum, there should be a couple threads with a picture dictating this.
Old 12-12-2007, 11:06 PM
CivicSpoon's Avatar
There is no Spoon
Re: Fring order
Old 03-22-2008, 04:54 PM
drew26 drew26 is offline
Re: Fring order
Does anybody know the firing order for a 1997 honda civiclx 5speed 1.6liter sohc..I disconected the plugs to the distributor cap and i can't get the right order..
Thank You
Drew
Old 03-24-2008, 08:03 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Fring order
1. Please dont bring up old threads.
2. Should be the same.. 1-3-4-2
Old 03-29-2008, 02:34 PM
moosehead4242 moosehead4242 is offline
Re: Fring order
HELP!!!!!! New to this site!! I need picture of firing order for: 1984 Chevrolet Truck C10 1/2 ton P/U 2WD 5.0L 4BL ...THANKS!
Old 03-29-2008, 02:53 PM
somick's Avatar
somick somick is offline
Re: Fring order
mooshead, you post your question at Honda forum. I doubt honda guys will have an answer for you.
Post your question at the S-10 forum:
http://www.automotiveforums.com/vbul...play.php?f=121
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 03-29-2008, 04:06 PM
Kind of a Big Deal
Re: Fring order
2 seconds on google.. http://www.boxwrench.net/specs/chevy_sb.htm
