Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-12-2007, 08:31 PM
FFjwhite's Avatar
FFjwhite FFjwhite is offline
Send a message via AIM to FFjwhite Send a message via Skype™ to FFjwhite
How to remove Moisture from my Headlights
Well as the title says how do I remove moisture from my headlights. Or why is this be caused. Any Ideas? Thanks
Old 12-12-2007, 08:35 PM
1996Chreokee 1996Chreokee is offline
Re: How to remove Moisture from my Headlights
A buudy of mine works at a stealership and says they can take them apart and reseal them ... he said its a real reasonable fee... maybe you could do it yourself
depending on the year you might be able to get it covered under warranty
Old 12-12-2007, 10:59 PM
FFjwhite's Avatar
It is only a 2002 and I bought it used yesterday.
Old 12-13-2007, 04:08 PM
j cAT j cAT is offline
you will have to remove the headlights and use hair dryer or place on something that is warm to dry out the moisture then put a clear sealant on all the seams. put silicone grease on rubber lamp gasket when installing . this worked for me. if you don't keep moisture out reflective coating will fail.
Old 12-13-2007, 04:26 PM
FFjwhite's Avatar
Ok great, I will have to give that a try. Thanks
Old 12-13-2007, 08:32 PM
HeMi101's Avatar
HeMi101 HeMi101 is offline
Send a message via AIM to HeMi101 Send a message via MSN to HeMi101 Send a message via Yahoo to HeMi101 Send a message via Skype™ to HeMi101
Another thing you should do is check the vents on the back of the lights and make sure they are not clogged. Mine were messed up, and i pulled the vent plug thingys out and now I only have moisture for a few hours when i wash teh car.
