Old 12-12-2007, 06:12 PM
Robby420 Robby420 is offline
Whats wrong??
I have a 92 cavalier and the fuel injector had a crack in it so i replaced it and now it don't even want to stay running. I've even tried a different injector. Whats wrong!!!
Old 12-12-2007, 08:44 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Whats wrong!!!!
fuel pump, CPS, another bad injector, fuel filter, coil pac, wires,
one bad injector, the car would still run but stumble horribly.. Little more info would be helpful.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 12-13-2007, 03:57 PM
Re: Whats wrong!!!!
the car ran fine before i replaced the injector bun then i went to start it and sounded like it was only running on one or two cylinders. Checked 4 spark on all 4 cylinders have spark i tried two different injectors and one i know works fine. I did crack one of the vacuum lines but fixed it.
Old 12-13-2007, 11:07 PM
shakewell shakewell is offline
Re: Whats wrong!!!!
Is the Check Engine Light on? Do you know for sure that you plugged all of the injectors back in properly? Try pulling off each injector connector one at a time while the engine is running - the one that doesn't make the engine bog down when you pull it off is the cylinder that is giving you trouble. Then you can focus on that cylinder. If none of them seems bad, check vaccuum leaks again and make sure nothing else (like the fuel pressure regulator) is unplugged.
