Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-12-2007, 03:50 PM
hbracing hbracing is offline
99 explorer misfire when cold
multiple misfire and both banks lean codes. Runs crappy only when cold
Old 12-12-2007, 06:12 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 99 explorer misfire when cold
Welcome to the forum!
Have you done anything to attempt to resolve this? Which engine does your Explorer have? When was the last time a tune up was performed?
-Rod
Old 12-12-2007, 06:40 PM
At this time All I know it is a V6 and the tune up is about a year old but the plugs look good. Have not ohmed the plug wires yet. We are not getting the correct voltage at the map sensor from the harness. Any help would be fantastic...........
Old 12-12-2007, 09:06 PM
TeamExploder TeamExploder is offline
Send a message via AIM to TeamExploder
Under your hood it will say 4.0 SOHC on a plastic piece usually and the 4.0 OHV looks like this http://img74.imageshack.us/img74/574/xpic2sn4.jpg
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1999 Malibu. 2.4L DOHC Auto
2000 Explorer XLT 4X4 Auto 4.0 SOHC
Old 12-12-2007, 09:46 PM
It's my sons car and I won't be able to contact him till later. As soon as I find out which one it is I will pass it on. I am very interested in your input and appreciate everyones help.....Thankyou
Old 12-12-2007, 10:17 PM
shorod's Avatar
SHO No Mo
The MAP sensor has 6 wires to it, right? On the Red wire you don't have battery voltage, or are you referring to one of the other wires not having the correct voltage?
The Red wire to the MAP shares its feed with a lot of other components, including the fuel injectors, fuel pump relay coil, oxygen sensor heaters, PCM, and Idle Air Control.
-Rod
Old 12-14-2007, 04:58 PM
Thanks for all your help!! After reading other posts our problem is in the intake gasket. We used propane to search the leak out. where it didnot show up before (because the engine was warm) it leak was found and is currently being repaired. Again thanks for all the help................
Old 12-14-2007, 06:13 PM
No Problem Anytime, We Try To Help As Best As We Can.
