Old 12-12-2007, 01:53 PM
StopfaknGT StopfaknGT is offline
Sohc Atx
I have a 97 base and it"s having tranny problems so i figured it'll be easier to swap in another ATX than troubleshooting this one. I guess my question is does the stealth sohc ATX fit the 3000gt sohc? has anyone done the swap before? Its my DD so i'd like to get it fixed ASAP. Thanks
Old 12-12-2007, 02:04 PM
Crackhedbob341's Avatar
Crackhedbob341 Crackhedbob341 is offline
Re: Sohc Atx
yes, they are the same as long as they are sohc. go to your mechanic, diagnose the problem, and get an estimate. another tranny is going to put a hole in your pocket.
or better yet, explain the problem, and maybe we can help you.
Never bring show to a go fight.
And a TT conversion brewing..
Old 12-12-2007, 05:01 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Sohc Atx
SOHC or DOHC ATX transmissions for 3000GT's and Stealth's are the same thing. Only differences might be in the TCU between SOHC and DOHC for different shift points.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 12-12-2007, 05:12 PM
ZRYDERVR4's Avatar
ZRYDERVR4 ZRYDERVR4 is offline
Re: Sohc Atx
there are some shops that will diagnose the problem for free so that you might stick with them to get the problem fixed through them.
Originally Posted by BlinkRA182
Basically, just choose on looks.
Originally Posted by Morphius289
Well, if that's the way people choose between 3000's and Stealths, than we wouldn't have any need for Stealths, would we?
Old 12-12-2007, 05:16 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Sohc Atx
Yeah TCU is probly different since SOHC has 6k redline. As long as the trans is from a 93+ SOHC it should be the same with a 93+ DOHC
Old 12-12-2007, 07:56 PM
Re: Sohc Atx
shizzat. i was thinking of manual/atx trannies being different by the flywheel and clutch difference, not sohc to dohc. my brain works too fast to filter. neva mind.
Old 12-14-2007, 11:41 PM
Re: Sohc Atx
Thanks guys. I found a shop to take it too. If all else fails I can get Seth(Toddrs93 on 3si) to rebuild it for me. Very cool guy
Old 12-19-2007, 04:14 AM
Re: Sohc Atx
The tech said i'd need a rebuild. Something about the clutch packs being bad. Car has 189k and this is the first trans rebuild/replace. $300 to put in a trans for me, $700 to rebuild, which would you say was the better choice? if anyone has a trans from an sohc stealth or GT pm me. thanks
Old 12-19-2007, 07:20 AM
Re: Sohc Atx
i would say rebuild. I don't think the price of a new transmission, plus shipment from a member here to you would be any lesser than the rebuild. but that's just my opinion.
Old 12-19-2007, 09:45 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Sohc Atx
New (Used) Lower milage trans FTW.. If you get it rebuild I would make a large bet that when the crack it open the will "Find" more problems with it and It will end up costing you more money!
Jason
Old 12-19-2007, 10:41 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Sohc Atx
If you know that the transmission you're looking at is good then I wouldn't rebuild. Jason said it best. Seven hundred for a rebuild isn't bad but they could find more problems, which is highly probable. You're better off with a different tranny.
Old 12-19-2007, 10:54 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Sohc Atx
Also agree with new or low milage FTW. That way you know its got no issues
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 12-19-2007, 12:17 PM
Re: Sohc Atx
I'm gonna go against the others here, if its a reputable transmission shop I would personally opt for the rebuild. A rebuild kit should come with everything they would need, so there wouldn't be a reason for any extra problems. The problem with buying used parts is, no matter the mileage, you never know how it was treated or how long it will last. And being that our ATX transmissions are very delicate (aka weak when abused) that's not a risk I would want to take. With a rebuild it's like getting a brand new and unabused transmission.
It's also a risk that I didn't take when the ATX in my SL gave up. I ended up just converting it to 5-speed. Slightly more expensive than either of your options, much more time consuming, but more reliable not to mention faster and better on gas.
Old 12-19-2007, 02:03 PM
Re: Sohc Atx
yeah.. i wouldn't have bought my car if it didn't have stick. it would be worth it to go manual IMO. less messy parts than an auto.. and lighter! :-D
Old 12-19-2007, 03:55 PM
Re: Sohc Atx
I can't thank you guys enough for the help. well the shop is owned by my dad's buddy. i would buy all the parts from ipt and he would do the rebuild. I understand exactly what you mean Twisted and that makes alot of sense. if I don't choose either or, then I'll probably go with a manual conversion. I think Yogurt on 3si is selling a kit for $600. Again, i really appreciate the help. AF Rocks man
