| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
I came across this while i was researching earlier today and i was curious... Is it worth it to install an oil catch can? Could i do it myself easily? Heres the one i was looking at.
Thanks http://www.slowboyracing.com/estore/...at=4066&page=1
97' Eclipse RS 5 Speed 420A Under The Hood: Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires Interior: Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout *GOAL* - Prove Him Wrong Quote: Originally Posted by UnderEstimate Me I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs. |
Re: Oil Catch Tank
Its simpler than changing your airfilter dude. Under no circumstances would I pay $70 for one though...
Re: Oil Catch Tank
What would be a good brand to go with? About how much should i be spending?
-Also, is it better to get one with the little filter on it, or not?
97' Eclipse RS 5 Speed 420A Under The Hood: Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires Interior: Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout *GOAL* - Prove Him Wrong Quote: Originally Posted by UnderEstimate Me I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs. Last edited by rickyrickster25; 12-12-2007 at 07:30 AM. |
Re: Oil Catch Tank
What are you hooking it to? Do you have a problem with oil coming into your intake via PCV valve or the valvecover breather? I had problems with oil coming out of the breather on the drivers side of the VC so I hooked a catchcan to that line and put a small filter on the other end.
If you hook it to the PCV valve system you will need to connect the other side to the manifold.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: Oil Catch Tank
My friend and I made one out of shit from Ace hardware for about $4 its not brain surgery. Filter or not doesnt matter, you just need to rehook the nonfiltered ones back to the intake hose.
Re: Oil Catch Tank
any pics of the setup? can find a "safe" place to put it...
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines" --2OF9-- (DSM team specialist) ;D #808/1000 |
Re: Oil Catch Tank
I was more or less looking for a little more info about catch tanks, i read that oil always seeps into the intake, but im not sure if thats true... It said something bout the engine working harder because of having to clear the oil out of the intake tract.... thus loosing some power...
Bullshit?
Re: Oil Catch Tank
It's kinda true. More like the motor choking on oil and burning it up. But again mostly on turbo/super cars. N/A not really.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Oil Catch Tank
So im assuming then it would be a waste of money? Or should i get it anyways just because?
Re: Oil Catch Tank
If your not turbo I wouldn't worry about it. I never had a problem till I was boosted, this is because of the increase cylinder pressure causing more blow-by. And I only have a problem when laying on the gas and turn right real hard since the oil slings to the breather on the VC and gets shot out. And yes it does shoot out. Its covered the whole underside of my hood before the catch can. I had to JB weld the nipple in the VC cause it would shoot the whole thing out.
Re: Oil Catch Tank
hey i was looking to install one soon as well, does anyone have any photos of one hooked up to their dsm? id kinda like a photo to go by if possible
also, best mounting location?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges |
