Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-11-2007, 04:51 PM
shortythespanish shortythespanish is offline
Help!!! 2000
My Boyfriend is having big problems with his 2000 Boneville.
His passenger side windows first went out,then his engine started stalling sometimes while driving without warning,just cutting out all of the sudden,he works allot and cant figure it out,any suggestions? we had thought to take out the Buss and clean all that up but we arnt aware of where it is and exactly what to do?any suggestions would be greatly appriciated!!!
Old 12-11-2007, 05:50 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help!!! 2000
Welcome to AF!!
As for the window check the wiring going from the switch to the motor and the wiring as it comes through the door. These are usually where the problems lie. As for the stalling, if he can restart the car right away after it stalls, I suggest you replace the crank position sensor. Random stalling is a common problem on GM cars and a classic symptom of impending crank position sensor failure.
Old 12-11-2007, 06:03 PM
Re: Help!!! 2000
well the thing is,ive read several things that says the wiring for the Passenger side windows,locks, and the fuel pump are all run through the same buss,and hooked up to the same wires,in the driver side floor...sometimes it will just stall when he is driving,and then sometimes if you leave it for several mins.you can restart it,but theres a good chance its going to die again in 5 mins.
Old 12-11-2007, 06:10 PM
Re: Help!!! 2000
it just seemed odd to me the passenger side window went out just a few days before it started stalling.and several people suggested maybe it was the fuel pump,which is what "these wires" are hooked up to and supposadly can shut off the fuel pump,along with passenger side windows,locks,and heated seats,
http://www.bonnevilleclub.com/forum/...=article&k=102
If someone could tell me where the buss is,itd also be appriciated,because to me this link describes what is wrong...
Old 12-11-2007, 06:30 PM
maxwedge maxwedge is online now
A990 racer
Re: Help!!! 2000
Under the l/s sill plate front door area, pull the carpet up, open the taping to access.
Old 12-11-2007, 08:11 PM
Mickey#1 Mickey#1 is offline
Re: Help!!! 2000
The ground locations changed with the 2000 model year. That article won't apply to your car. Best thing to do is check for fuel pressure &/or spark next time it won't restart. With the information we have so far I'd agree with GTP Dad that the crank sensor is failing.
Old 12-11-2007, 08:31 PM
Re: Help!!! 2000
ok thanks,ill let him know and we'll see if we can get things fixed,i just thought it was weird with that artical and all about the window,and how it stopped working the same week that it started stalling?
is the crank position sensor hard to replace?where is it located?And any idea of how much it would cost to have it replaced by a mechanic?like i said he works allot so he doesnt have much time.i know most of these questions most likely seem dumb but i dont know much about cars.
thanks!
Old 12-12-2007, 07:07 AM
Pontiac Guy
Re: Help!!! 2000
The sensor is not hard to replace it is just hard to get to. The biggest problem is getting the bolt loose from the front of the engine. For this you will need an impact wrench. Access can also be a problem. If you don't have a good place to work on the vehicle take it to a mechanic it will be much easier on the back and worth the money. Probably a $200 job with the parts.
Old 12-12-2007, 01:31 PM
Re: Help!!! 2000
ok,thanks,ill let him know!!! hopefully thats the problem.any other suggestions if thats not it?
i talked to him about it some today and he said only one time has it kimda sounded bad before it died,most of the time it gives no warnings or anything,ive been with him when it died in the passenger seat and i didnt even know it died because i couldnt hear or feel anything.
Old 12-12-2007, 06:27 PM
A990 racer
Thumbs up Re: Help!!! 2000
Mickey#1, thanks for the correct info here.
Old 12-12-2007, 06:47 PM
Re: Help!!! 2000
despite everyone saying it couldnt be the buss we desided to clean and re-connect the wires anyways,and to our suprise,his passenger window now works,and the car so far has ran for 40 mins!!!!hopefully it fixed it,ill let you all know within a couple days if its all good.thank you all so much for your help and imput.
Old 12-12-2007, 08:57 PM
Re: Help!!! 2000
Can you tell us which wires you cleaned? A pic would be great.
Old 12-13-2007, 05:46 AM
Re: Help!!! 2000
he lives in a different state then me and doesnt have a digital camera but i know where it was so ill do my best to describe it.
on the passenger floor board,up on the rocker panel.it wasnt dirty or anything he said but he took it apart and wrapped the wires around the buss (or ground,same thing) better and migically everything worked.he said its probably because everytime you get in and out of the car you step on it,so eventually it pulls it loose. hopefully this is our problem,and hopefully this thread can save somebody some major money
