i have a 2004 chevy silverado, where are the grease fittings and any other lube points on this truck?
Thank you |
Re: grease fittings
None.
Re: grease fittings
None? Did they change it from 99-02 body styles? My 02 has zerk fittings.
2002 1500 Ext. Cab 4.8L 2wd. K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights. |
Re: grease fittings
the information in the online application guide at amsoil.com said that my truck has 6 zerk fittings but i need to know where they are.
Re: grease fittings
'03 and up have either 11 zerk fittings or 6 depending upon if you have 4wd..actually i think they should be the same from '99 up. Heres a list/location of all 11
Driver Side 1)Upper balljoint 2)Outer Tie-rod End 3)Lower Balljoint 4)Inner Tie-rod End 5)Pit-man Arm which is located at the relay rod Passenger Side 1)Idler Arm-located at the relay rod 2)Upper end of Idler arm mount 3)Idler Arm-at relay rod 4)Inner Tie Rod End 5)Lower Ball Joint 6)Outer Tie Rod End 7)Upper Ball Joint If you have a 2wd truck then you only have six that just include the four ball joints and the two outer tie rod ends. Hope this helps..I know theres a message board somewhere with the pictures..I'll let you know if I find them
2008 Silverado LTZ Z71 Extended Cab "The Winner isn't the one with the fastest car, it's one who refuses to lose." #3 |
Re: grease fittings
You guys are correct, my mistake.
Re: grease fittings
on the 03 the 2500hd 2 wheel drives and the 1500 4x4 all have 11. I have one of both of them
Re: grease fittings
Additionally, if you have had a U-joint replaced, it/they are more than likey greaseable.
It may not apply to this specific truck, but many/most "slip-in-shaft" driveshafts are greaseable. I also lube all bushings (A-arm, sway bar, leaf spring shackles, etc., anything that moves) at least twice a year with a silicon based spray.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
