Old 12-11-2007, 10:00 AM
DaveN DaveN is offline
VW T1 or T2 Bus build tips?
Hi
I have bought Hasegawa's VW 23 Window Samba, Pickup and Delivery with some customising/lowering in mind. I have searched around but cant find and Build Diary. I'm looking for a method to lower the suspension, do I need to cut the wheel arches and scratch build replacements?
Dave N
Old 12-11-2007, 12:39 PM
deedlit's Avatar
deedlit deedlit is offline
Re: VW T1 or T2 Bus build tips?
Originally Posted by DaveN
... do I need to cut the wheel arches and scratch build replacements?
Not a lot of solutions with this kit:
- or you set large rims and you'll have to cut
- or you limit the size of the rims to 15' and you can have a right riding height.
Old 12-11-2007, 01:10 PM
M-Tuning's Avatar
M-Tuning M-Tuning is offline
I had to cut to get this stance:
My Gallery:
http://www.M-Tuning.nl
Old 12-11-2007, 01:50 PM
oter oter is offline
here is one i did build,i had to cut too:
Old 12-11-2007, 04:28 PM
Did you still use the original suspension but with it shortened?
Dave N
Old 12-12-2007, 11:33 AM
MattRS2000 MattRS2000 is offline
I cut a section from the front assembly, and made a small slot to recess it even further:
Wheel wells are easy to make, the seat also needs some material removed to fit nicely:
Here it is on a set of narrowed Fuchs:
I hope that helps.
Matt
Old 12-12-2007, 05:06 PM
Thats great show he front mods perfectly. Nice build up.
Thanks
Dave N
Old 12-13-2007, 03:04 PM
tapetape tapetape is offline
Sorry to intrude on this thread but to save making another about the same/similar model I thought i'd post here.
I have just purchased the Hasegawa VW Type 2 Delivery Van and I was wondering if there was any build diary/WiP threads on this model or a similar one. And does anyone know any good sites for reference pictures as I have had no luck finding any.
also is 0.5mm thick styrene a good thickness to use for scratch building/modding?
Edit
Also will I have to buy the '88 porsche 911 turbo for those Fuch wheels?
Thanks.
Old 12-16-2007, 03:24 PM
tapetape this link might be of interest seeing as we are trying similar projects.
http://www.busselecta.com/
Old 12-16-2007, 03:26 PM
Thanks for that link it will definatly be helpful! ...and fun to play with =P
Old 12-20-2007, 02:29 PM
scrappyj1 scrappyj1 is offline
Dave-
I scratch built my entire frame and suspension. I have a coil-over set-up, where I scratch built the lower A-arms out of plastic. A lot of work, but as stated earlier, not many options on these. I did a 21-window years ago, where I used as similar method on the chassis, but used the kit's front suspension.
The link to my recent post
http://www.automotiveforums.com/vbul...d.php?t=772330
