Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-11-2007, 03:49 AM   #1
Andres_S427
94 Lumina Antifreeze
Hello, I have a 94 Lumina Euro that is leaking antifreeze. My car overheated and I noticed there was no antifreeze in my radiator[COLOR=green ! important][COLOR=green ! important][/color][/color] or my reserve and when I added some after the car had cooled down it poured directly out of the bottom of the car but not from the radiator more from the middle of the engine around the oil filter. The car still starts up but will not hold antifreeze. I am not sure what the problem is and am thinking it is the water pump. Any ideas?
Andres_S427 is offline   Reply With Quote
Old 12-11-2007, 07:11 AM   #2
richtazz
stupidity should hurt
richtazz's Avatar
Re: 94 Lumina Antifreeze
The water pump is mounted high on the passenger side, so unlikely. It sounds like you blew a freeze plug in the block and that's where your leak is coming from. Relatively cheap part, but a PITA to change. If it's the one in the center of the block toward the front of the car, you'll have to drop the starter and possibly the AC compressor to get to it.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
richtazz is offline   Reply With Quote
Old 06-25-2008, 12:57 PM   #3
Andres_S427
The car has not ran since. It will start up but when put into gear shuts off. There is a hollow sound when idling, sort of like a diesel.
