Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-10-2007, 09:34 PM
ABigWeaney ABigWeaney is offline
solid tensioner?
OK i was going to buy the timing components, and i was wondering if the BLE solid tensioner would be better then the hydraulic tensioner?
Here is where i found it.
http://www.extremepsi.com/store/cust...at=1328&page=1
Old 12-10-2007, 09:41 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: solid tensioner?
Interesting... I have never seen anyone use this kind of tensioner. I have heard of people going to the mechanical tensioner but not something like this. When I build my motor im going to stick with the hydrolic tensioner. Its been proven to work and hold up.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-10-2007, 11:14 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Looks cheap for that price. A hunk of metal with holes punched and a bolt n nut..wow :/ Looks highly unreliable.
2004 Mazda 6i
1997 Tahoe
Old 12-10-2007, 11:15 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
That doesnt look like a good idea. What happens when the belt strethes over time? I guess you have to keep tightening up that bolt...thats boo boo. I'd stick with the hydraulic tensioner so it will keep tension on the belt when it strethes.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 12-10-2007, 11:22 PM
MazdaX's Avatar
Not to mention with heavy pressures and vibrations it can cause the nut and bolt to loosen over time. Might end up costing you a head job :/ 97.00 isnt worth 3 - 400 in repairs later.
2004 Mazda 6i
1997 Tahoe
Old 12-10-2007, 11:36 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
http://www.ecanfix.com/~mdhamilton/tensioner.html
Worth a look at
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 12-11-2007, 08:31 AM
Holset powered 420a
Not to mention a new hydrolic tensioner is cheaper than that bolt contraption. Is there any reason why you dont want to use the hydrolic tensioner??
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-11-2007, 09:32 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Hello... Have you people never heard of loctite? The bolt won't rattle loose and it can't fail like a hydraulic tensioner... Of course that isn't saying it is any better than a regular one...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-11-2007, 10:22 AM
Holset powered 420a
I think your motor is more prone to crankwalk then failing from a broken hydrolic tensioner. The only possibility is if it was super old and you didn't replace it with the rebuild.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-11-2007, 12:39 PM
I've never heard of a hydraulic tensioner failing. I've replaced mine a few times though so I ain't worried about it.
Caleb
vanilla gorilla
Old 12-11-2007, 08:35 PM
Testiklees
A solid tensioner would be for a drag only car. The timing belts stretch and that slack is taken up by the hydraulic tensioner push-rod.
Tim
1990 Talon AWD
PTE SCM5031
Old 12-11-2007, 08:40 PM
That is what i thought.. but i did not know what to do about the belt stretch. hydraulic is how i will go then thanks guys.
Old 12-17-2007, 02:04 AM
kjewer1 kjewer1 is offline
AF - Advisor
Hydraulic tensioners can fail and cost a race car owner a shitload of cash. I can only imagine that very heavy valve springs and serious cams ("square" lobed) put a ridiculous amount of stress on the hydraulic tensioner. People in those cases might find a use for one of these, but naturally they don't drive the car daily and the tbelt probably gets replaced more often than the oil.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
