Old 12-10-2007, 08:51 PM
cfrank2 cfrank2 is offline
oil change (drain plug)
I have a 2004 chevy silverado with a 6.6L V8 duramax diesel, i have heard from some people that there is a crush gasket on the drain plug is that true. What is the actual name of that gasket?
Thanks
Old 12-11-2007, 12:51 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: oil change (drain plug)
Thanks
It's possible, but drain plugs can be replaced. I've seen two and they both had the rubber ring in a recess in the drain plug. Just look at it the next time it's out. If there is any material on it that you can deform with your fingernail, it's not the crush type. It's probably just called the "drain plug gasket".
Just curious, but what about the type of sealing method would make you bang your head on the wall?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-11-2007, 06:50 PM
j cAT j cAT is offline
Thanks
on my sil 5.3 I have oil drain plug that is steel with a rubber seal that seats in a groove where it touches the oil pan. torque to 15ft lbs. 110,000 mi same plug no leaks. also plug has magnet on tip
