Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-10-2007, 04:26 PM
phlax18 phlax18 is offline
'04 Grand Cherokee Electronic Problems
I have a 2004 GC Laredo, the the power windows don't work, the interior lights never turn off...have to turn them off manually. The power door locks also don't work on the driver side....and the keyless entry locks and opens every door but the driver door...is it a wiring problem or a fuse problem...or what is it?
Old 12-11-2007, 10:15 PM
xj31 xj31 is offline
Re: '04 Grand Cherokee Electronic Problems
You probably have a broken wire in the harness going into the drivers door.
Old 12-13-2007, 08:19 AM
DennisPer DennisPer is offline
I have similar problems with my 2004. Dealer says the body control module needs tp be replaced
Old 12-13-2007, 07:22 PM
That could be the case,but I would take a look at the wires in the drivers door jamb.I see this a lot
Old 12-14-2007, 12:59 PM
legalfee legalfee is offline
I had the problem with the drivers door power lock (unlock) not working. It turned out to be a bad actuator inside the door. I guess the drivers door gets used a lot more than the other doors.
1984 AMC Wagoneer Limited (RIP - Burned)
1996 Chrysler Grand Cherokee Limited (for sale)
1999 Chrysler Sebring Convertible JXi
2004 BMW X3
Old 12-26-2007, 03:04 PM
ericpaul80 ericpaul80 is offline
i agree w xj, i had this problem in my jeep. you just open the door, pull of the flange cover, slide it over to reveal the wires and look for the frayed covering. Mine was the ground wire. I just got a wire connector, spliced it together and then wrapped it w/ electrical tape. No problems since. Good Luck.
Old 12-26-2007, 08:15 PM
jdm5646 jdm5646 is offline
I have the same problem/ Started with key fob not unlocking driver door (this problem came and went for a few weeks) then interior lights not shutting off (also coming and going), now along with all others issues listed above...none of the power windows work and no remote mirrors. Vehicle just went over 70K when first issue arose. Does this sound familiar?
How do you remove door control unit from driver door?
Old 12-27-2007, 11:04 AM
Like i said before, try to undo the flange between the door and the car first (use a flat head screw driver to pry it off) and look at the wires, it may just be a frayed wire that you need to splice or just put tape around. if this isnt the problem then you need to get a special pry bar from a parts store to pop off the connectors around the inside panel (there is about 5-10 of them around the panel, and be careful b/c they break easily) and then you can lok at the connections for your locks and windows. Try the wires first though.
Old 12-27-2007, 02:37 PM
THANKS - ericpaul80 - hadn't had chance to try out prior to my post. Just had chance to look at. Removed boot. Found GROUND wire severed completely and two others crimped. Repaired and taped up, re-installed. All works fine. Thanks again. vbmenu_register("postmenu_5569361", true);
Old 12-27-2007, 04:53 PM
glad to help!
Old 06-25-2009, 12:04 PM
nowrb nowrb is offline
Thanks I found two broken wires on mine too "))
