Old 12-07-2002, 12:43 PM
civicHatch civicHatch is offline
Send a message via AIM to civicHatch
Please help with exhaust fitment!!!
I own a 88 civic dx hatch. I desperatly want to use the Apex N1 2.5" universal canister with custom piping. Heres the problem: The place that will be doing the pipework (mandrel bent) says that i cannot run 2.5 over the rear crossmember because they say it just wont fit. He said I can run 2 1/4 the whole way or run 2.5 from the cat back to the crossmember and run 2 1/4 just over the crossmember. I am going to be running the exhaust on the stock engine for a while untill i swap a b16a gen 1. The exhaust will be exiting out the passenger side, not the stock position. Will the N1 even fit? Also, I want the muffler to be tilted up and kicked to the side. Can i do this by going over the crossmember? Can I go under the crossmember or is that too risky for a daily driver. Any help would be greatly appreciated as i am getting the setup very soon. Whats the Best Set-up?
Andrew
Old 12-07-2002, 03:02 PM
GTA's Avatar
GTA GTA is offline
Whee..
you only really need 2 1/4 piping...even when you get a b16. Only need to go bigger if you are going turbo.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 12-08-2002, 06:04 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
The right shop can run 2.5 all the way back without clearance problems (I've done it before). I would suggest though that you run 2 1/4" pipe from the cat-back and i suggest putting in a glasspack as a resonator or else you'll be heard from a mile away. You can run the pipe over or under the REAR LCA (it's not a crossmember) I always prefer to run it over the LCA though.
Old 12-10-2002, 12:07 AM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
2.5" is overkill on a na motor..........you still need some back pressure.....my cousin has a 2.5" cat back full mandrel bends on his totalled si (for sale) and that thing is loud....his runs over the rear lower control arm...I don't know about the glass pack thing.....just run a cat that should help....oh wait.....you guys have to run one......damn emission test......we don't have those here......whats a cat??
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
Old 12-10-2002, 12:23 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
u live in the u.s. so you have to have one....."cat" is short for catilytic converter <~~~now quite sure how it is spelled hehe......im borderline illiterate
Old 12-10-2002, 12:38 AM
91civicDXdude's Avatar
wrong. its not the backpressure you need, its the usable power band. backpressure = bad. when people say you need backpressure its because having too much of a good thing (too big of exhaust) will make the exhaust gases have less velocity which makes them scavenge not as well.
Also, when people say you lose torque with too much flow, they are wrong. you do not lose the horsepower it simply moves up in teh powerband. basically, what you are doing by having too large of exhaust is tuning an engine to make power in too high rpm for that engine to even rev. basically, unusable power.
backpressure is still bad. oh, and btw, i have 2.5 inch catback on my car BUT it is crush bent so that helps with the bends restricting airflow. I had the shop run it over my LCA and it never hits.
Old 12-10-2002, 01:32 AM
I know what a catalytic converter is.........but here in middle wisconsin there is no such thing as emission tests or vehicle inspections (not unless your car is an absolute p.o.s and they want it off the street like my festiva) I got a ticket with my festiva and the cop wrote " safety hazard, health hazard,road hazard" pulled my registration.....HAHA.....anyway.....we either pull our cats here or hollow them out empty.......and 91civicdxdude.....thanks for the correction either way too big makes it unusable which makes it worthless right??? or no.......cuz if Its good I'll but my cousins shit on my ride......I have 2" mandrell bends now...
Help with airbrush fitment/adapter billypee Car Modeling 8 02-05-2007 11:11 AM
Please help with exhaust info Bad_Bird'99 Tiburon | Tuscani 5 10-24-2005 11:33 PM
need help with exhaust Kdawg02 Integra 3 01-25-2002 12:55 AM
