Old 12-10-2007, 01:30 AM
outthereNJ outthereNJ is offline
Lazy transmission. what to do??
I have a 96 S-10 Blazer, automatic. I am feeling very much that i'm not getting the power that i'm supposed to from it. I get decent movement from 1 to 2nd, but it seems that from that point it shifts to higher gear and it wont drop back down when i need it, unless i floor the pedal. when i hit a big hill it stays in a high gear and i cant get much pull. The shifting feels like when you have a manual trans and your easing in the clutch. i know its not natural, but i dont know what to do. can anyone help?
Old 12-10-2007, 07:54 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Lazy transmission. what to do??
How long since you've changed the transmission fluid AND filter?
Old 12-10-2007, 08:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Also keep in mind that a engine has to be runnning good for the transmission to work good.
MT
Old 12-13-2007, 09:15 PM
i cant say for sure because i've only had it for a few months, but the fluid is still red, and when i took it to the mechanic the diagnotic showed no codes.
Old 12-14-2007, 08:53 AM
MT-2500's Avatar
AF - Advisor
I would find a good repair shop with a good scanner.
How is the engine running end or tune up?
MT
Old 12-14-2007, 07:03 PM
peterjon1 peterjon1 is offline
Check for vacuum leak also. Mine was similar, plus surging at cruise. Found the 7/16 in vac line split. Has much more zip now.
Old 12-14-2007, 10:13 PM
where would i find it?
MT-2500 - it was tuned up when i bought it, and the mechanic i took it to didnt find anything wrong related to the engine or trans.
Old 12-16-2007, 12:04 AM
On mine, which is the vin Z motor, there is a vacuum nipple on the top of the intake manifold, with a rubber line that goes toward the firewall. All looked ok at first, but when I yanked on the line, it separated waaaay too easy from the nipple. The hose was deteriorated from the engine heat and cracked right at the nipple. You may be able to just cut off the end and reattach, but a new hose is like 4 bucks for a 6 foot length, so I replaced the whole thing. I had problems with lack of power and surging, sluggish acceleration above 2nd gear. All is fine now. I had myself convinced it was a tranny problem too. The rpm would vary, like the tc was locking, unlocking repeatedly. That was the lean mixture surge caused by the vacuum leak.
Old 12-16-2007, 05:03 PM
yeah, that sure sounds like my problem. i will check it out and report the outcome. thanks
