Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 12-09-2007, 09:35 PM
im_blowin_bubbles im_blowin_bubbles is offline
98 kia sportage won't start?
ok i have replced the timeing belt and it ran fine for about 6 monthes and then it was running and about an hour later i went outside and it will not start any ideas? oh and someone stole the converter before i replaced the timeing belt i also replaced the spark plug and wire. would running it without converter hurt it any? the plugs have spark and it will crank just not start have checked all the fuses and relays i need help bad only car please someone help
i have been told to check the 2sec fuel pump fuse under the rear right seat but i can't find it even when i opened the panel ideas would be helpful
thanks
dee
Old 12-10-2007, 02:55 PM
LMP's Avatar
LMP LMP is offline
Re: 98 kia sportage won't start?
Originally Posted by im_blowin_bubbles
...i have been told to check the 2sec fuel pump fuse under the rear right
seat
negative: no fuse there: what was told about that place is to check --since this is an access to the fuel pump module - if you can hear the fuel pump run for about 2 sec when turning the key to ON, at least to comfirm that the fuel pump is OK.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
