Old 12-09-2007, 10:34 PM
mike457 mike457 is offline
4g63 swap in s10
i want to put a 4g63 turbo engine in my s10 wud it work and wat kind of tranny do i use
Old 12-09-2007, 11:44 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 4g63 swap in s10
Small motor in big truck = lots of noise and a slow trip to the dairy.
If your really keen though you want a Toyota T50 5 speed with a rare as hens teeth 4age bellhousing.
You will need custom drive shaft to fit the toyomotor box to the chuvit diff, custom mounts to fit the motor to the chassis.
And if you need advice on how to turbo a 4age, then thats a whole nother problem, suffice to say there are cheaper and more powerful alternatives.
If your looking for a tranny this is the wrong forum. Try www.mendressedaswomen.com
Old 12-17-2007, 02:11 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Transmission from a Mitsubishi Mighty Max/Dodge Ram D50 Pickup should bolt up.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-17-2007, 03:55 AM
Moppie's Avatar
Master Connector
I don't why I was thinking 4age.
To many 4 and g's........
The Mitsi Starion has a 5sp that will bolt directly to the 4G63, and handle upwards of 300hp.
