Old 12-09-2007, 10:26 PM
AaronIROCZ AaronIROCZ is offline
02 silverado fuel mileage went down ALOT!!
I have a 2002 Silverado extended cab short box 4x4 with the 5.3L engine. I bought it in 2004 with 36000 miles and got around 19 mpg highway and 14 city. Now with 100000 and flowmaster cat back exhaust and brand new cat's from gm I get 10 mpg city and 13.9 highway. I also replaced the plugs about 1000 miles ago with ac delco rapid fire platnums and the fuel filter earlier this year (15000 miles). The truck still runs fine no loss of power or drivabilty but the gas mileage just sucks. Any ideas on how to get it better???? I am thinking of getting a cold air intake kit but I am not sure if that is a "cure" or a fix to my problem or if it is even a problem due to its age and mileage.
Old 12-10-2007, 03:52 AM
tempfixit tempfixit is offline
Re: 02 silverado fuel mileage went down ALOT!!
Have you checked for any codes?? Did the mileage get worse before or after the new exhaust?? Parts stores usually check codes for free. Post any codes.
Old 12-10-2007, 02:14 PM
Well there is no ses light on but I will check for them, I know that some don't light the ses light. The fuel mileage was real bad when the cats plugged up but it back to where it is now after the exhaust work.
Old 12-10-2007, 07:08 PM
j cAT j cAT is offline
I suspect the new exhaust system has much less back pressure, and this is the problem, as this will effect the pcm control on mixture and timing. I get 19 hwy and about 14-15MPG around town I still have stock exhaust. this is a stupid question but, the o2 sensors were replaced when the cat's were replaced ? I hope so............
Old 12-10-2007, 07:35 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
I lost a lot of MPG when I had the plugs replaced...
Old 12-10-2007, 09:42 PM
No I did not replace the o2 sensors.
Old 12-11-2007, 12:20 PM
the o2 sensors should be replaced every 100,000mi and whenever the cat's are plugged with carbon this is what I have read many times before. I have never had this happen to me cat's plugged but with the overly rich mixture which i am sure you have i would do this o2 replacement. the up stream o2 sensors control the pcm the rear sensors monitor cat performance.if you can get the o2 sensors checked with scan for a reasonable cost that would be also recomended before replacing the o2.
Old 12-11-2007, 09:36 PM
My work has a snap on scan too that should monitor the o2 readings, I will check that out, in the next few days. Thanks for the replys.
Old 12-15-2007, 02:55 PM
scottmoyer scottmoyer is offline
Just a few options...
The O2 sensors are a big possibility, also, the spark plugs may not be burning the fuel correctly. Verify the specs on the plugs to see if they match factory. Also, the exhaust will tear down your mileage, but should increase HP/Torque. It shouldn't affect it as much as you said, but it could change 1-2 mpg. You should also buy a few cans of Seafoam and run it thru the gas tank. This will be sure to clean the injectors. The intake might also need a seafoam fogging to eliminate the carbon buildup. Make sure you also use Top Tier gas. Do a search for gas stations providing such gas.
2006 Silverado Z71 - Blue Granite
2003 Monte Carlo Brickyard 400 Pace Car
1987 Camaro IROC-Z - 13k original miles
Old 12-19-2007, 01:08 AM
Thanks for the info Scott, I will try the seafoam and see if that makes a difference. I did check for codes, and did not come up with any. I also only run BP fuels, 89 with ethanol, and have been trying the 87 non ethanol to see if that makes a difference. I used to run the 92 ultimate fuel but that is a little expensive right now.
Old 12-19-2007, 07:34 AM
kklagge kklagge is offline
Just make sure you change your fuel filter after running the seafoam in your gas tank...it will pull all kinds of crap out of it and clog up the filter.
Old 12-20-2007, 02:25 PM
Well after 200 miles of highway driving and 75 miles in town it now is getting 10.7 mpg. I am putting it on the snap on modis to look at the o2 sensors data.
Old 12-20-2007, 04:09 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Look at IAC position and injector PW at idle while you're there.
Carbon buildup can cause both to go up (sending fuel mileage down). If they do, the PW stays high even after you step on the gas. IAC generally will be between 20 and 40 counts, PW less than 3 mS. Seafoam probably won't get it all, especially around the throttle body. You may need an induction flush.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-20-2007, 07:38 PM
Ok here is the main points of the data I got from the scan, engine running for approx 3 min
o2 b1 s1 ranging from 60 to 800 o2 b2 s1 ranging from 60-800
o2 b1 s2 around 789 o2 b2 s2 around 127 then after 2 more min went up to 780's. I did notice o2 b2 s1 not changing as fast as b1 s1 (bank 1 sensor 1) iac 83 inj pw 3.9 both banks
then after the engine running for 11+ min
o2 b1 s1 ranging from 60-800 o2 b2 s1 ranging from 60-800 not as fast
o2 b1 s2 around 742 o2 b2 s2 around 126
inj pw 3.2 both banks and iac around 40. From that data I am believing that bank 2 sensor 1 is in need of replacement, and in which case I will replace both primary sensors. Any other ideas or tips??
Old 12-21-2007, 07:03 PM
What about the catalytic converter? That too can drive the mileage into the bucket.
