Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-09-2007, 06:51 PM
mike561 mike561 is offline
window motor switch
Can anyone tell me what order the wires connect into the back of the window switch for the rear left door? the original wiring harness fell apart because it was so old and brittle so i just put connecters on the end of each wire. i have 5 wires, brown, green, red, blue and purple, what order do they go in on pins in the back of the switch like this
2006 Chevy Cobalt LS
Old 12-09-2007, 09:07 PM
Re: window motor switch
stumpped everyone again
Old 12-10-2007, 11:20 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
If someone doesn't already answer by then, when I get out of work I'll go into my car, take a switch out and look for yah. ~Pete
Old 12-10-2007, 11:21 AM
Ok sounds good, thanks, maybe take a pic if you can too
Old 12-10-2007, 11:48 PM
beat88ls's Avatar
beat88ls beat88ls is offline
Originally Posted by mike561
Can anyone tell me what order the wires connect into the back of the window switch for the rear left door? the original wiring harness fell apart because it was so old and brittle so i just put connecters on the end of each wire. i have 5 wires, brown, green, red, blue and purple, what order do they go in on pins in the back of the switch like this [IMG]http://i15.photobucket.com/albums/a367/pctvman/w.jpg[IMG]
lol not busting balls here but did you try looking at the other door to see what color went where?
1997 Jeep Grand Cherokee Laredo 4.0L
2004 Jeep Grand Cherokee Laredo 4.0L
1983 Caprice Classic 5.0L
Old 12-10-2007, 11:57 PM
I did consider doing that but i dont want the other wiring harness to fall apart either, cause im sure that one is just as brittle as this one was. if i have to though i will as a last resort
Old 12-11-2007, 08:13 AM
PeteA216's Avatar
Hey sorry, I didn't get a chance to get out there last night. I had some people over. Again, if nobody gives you the answer by tonight I should look by then.
Old 12-11-2007, 10:17 PM
PeteA216's Avatar
Okay I took off the rear passenger side door switch off and took a look. Suprisingly mine shows no signes of becoming brittle. Anyway, I made a diagram like yours (Mike) and realized that I might have to take off the driver's side rear switch because the colors dont seem to match the ones you stated that you have.
Old 12-11-2007, 11:34 PM
That did the trick, it works again. i sat out there for hours before, switching around all those wires. thanks pete! saved me a trip to the salvage yard and $$ too
Old 12-12-2007, 09:15 AM
PeteA216's Avatar
No problem, sorry it took so long.
Old 12-12-2007, 12:39 PM
Its ok
