Old 12-09-2007, 07:14 PM
teamster98 teamster98 is offline
Unhappy s-10 blazer heater fan
I have a 2000 s10 Blazer.The heat blowes usually in the mourning but coming home at night no fan.I allready replaced the relay.Any ideas?
Old 12-09-2007, 08:37 PM
old_master's Avatar
Advisor/Moderator
Re: s-10 blazer heater fan
Manual or automatic climate control?
When the blower works, do all 4 speeds work?
When the blower acts up, do all 4 speeds quit?
Old 12-10-2007, 10:19 AM
djd99's Avatar
djd99 djd99 is offline
Whats the difference between manual and automatic? How do you tell?
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
Old 12-10-2007, 11:06 AM
It has dial low to high and an auto setting.Either every speed works or none work.
Old 12-10-2007, 06:25 PM
old_master's Avatar
Advisor/Moderator
You have automatic climate control, that system is quite complex and requires a body capable scan tool to acurately diganose the system. You can check the blower motor, the blower motor feed wire and the blower motor ground wire connections. If those are OK, you'll need the scan tool.
