2000 Dakota Thermostat
Where do i find and access the thermostat on a 2000 Dakota with a 4.7 Liter Magnum V-8?
Re: 2000 Dakota Thermostat
If you look between the AC Compressor and the Alternator, you should see the Thermostat housing. Should be easy to access it. Be prepared for a loss of coolant as anything that is in the Radiator hose will be lost all over the engine.
2009 KIA Rio SX AT 1995 Eagle Summit DL Coupe |
4.7 t-stat is located at the lower rad hose.
yep. it may be on the lower side of the block.
lower rad hose at timing cover pass side of engine front
