Old 12-08-2007, 08:48 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Time needed for 4.3 engine swap
Hey, shop guys, what is the typical amount of labor time needed to swap out a dying 4.3 V6 for a used 4.3 V6 in a 98 Blazer 4x4?
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 12-09-2007, 09:52 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Time needed for 4.3 engine swap
computer at a friends shop gives an estimate of 12-15 hours to replace the engine.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 12-09-2007, 01:37 PM
534BC 534BC is offline
It depends on a lot of things. IT might take me a week or even 40 hrs.
A good r&r man can do it in a couple of hrs if everything is ready.
I guess it depends what you include in the term "swap"
Old 12-09-2007, 01:49 PM
Basically if they were both the same 4.3 engine or needed little modification to work (if it was a 4.3 from the Astro or something). Replacement would come from a junkyard vehicle. Both completely stock, no power mods or upgraded parts or anything.
I have coolant in my engine from excessive driving with a gasket leak and i'd rather swap in an engine over driving it til it dies.
Old 12-09-2007, 07:57 PM
herkyhawki herkyhawki is offline
Originally Posted by sickcallawayc12
...I have coolant in my engine from excessive driving with a gasket leak and i'd rather swap in an engine over driving it til it dies.
Why not fix the gasket?? mucho cheaper.
Old 12-09-2007, 08:43 PM
Oh, it is fixed. Was the typical intake manifold. After it was fixed my mechanic said the engine already had eaten a lot of coolant.
Old 12-12-2007, 02:08 PM
duke350 duke350 is offline
Depends on what exactly you are getting. My guide shows
15.9-18.75 Same engine (used) INCLUDES R & R OF COMPLETE ENGINE (WITH MANIFOLDS - COOLING & ELECTRICAL SYSTEMS INTACT)
22.3-23.5 For a long block & transfer parts. INCLUDES R & R OF MANIFOLDS AND ALL NECESSARY GASKETS - TIMING COVER - OIL PAN - CLUTCH - AND NEEDED ADJUSTMENTS ---NOTE--- IF YOU ARE NOT REPLACING GASKETS YOU SHOULD USE LABOR DESCRIPTION --> R & R ENGINE & TRANSFER PARTS
27.2-28.6 for short block & transfer parts. INCLUDES - R & R OF COMPLETE SHORT BLOCK ASSEMBLY - - - HOSES & BELTS - FUEL ASSEMBLIES - ELECTRICAL COMPONETS TUNE ENGINE AND MAKE ALL NECESSARY ADJUSTMENTS.
I have found this guide to be pretty accurate for most things.
