Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-08-2007, 07:00 PM
epadilla epadilla is offline
Unhappy 4x4 woes
short and to the point here. 1998 blazer 4.3L v6, 233 transfer case. i push 4hi and the drive shaft starts to spin but front tires dont. i put it in neutral and push 4lo the change over happens but no go on the front tires. i checked for codes, no codes are been shown, i checked for vaccum on top of the transfer case and there is good suction. i checked the motor it works, i checked the vaccum actuator and cable it all work. however something i did notice was the vacuum actuator under the battery tray is NOT bolted down. can that cause it not to pull on the shaft out all the way.??
Old 12-08-2007, 08:49 PM
old_master's Avatar
Advisor/Moderator
Re: 4x4 woes
This is a duplicate thread, here is a link to the original: http://www.automotiveforums.com/vbul...d.php?t=770203
Closed Thread
