Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-08-2007, 04:25 PM
rangermalloy rangermalloy is offline
Bleeding Question
I just changed the front calipers on my '92 Ford Ranger, and need to bleed my brakes since the pedal now goes all the way to the floor. Since the front and rear are on separate systems, do I only need to bleed the front brakes? I don't think I let the master cylinder go dry when I changed the calipers. Thanks in advance for any help.
Old 12-08-2007, 08:32 PM
TeamExploder TeamExploder is offline
Send a message via AIM to TeamExploder
Re: Bleeding Question
You may end up needing to do both front and rear if I remember right. Just to insure air hasn't gotten into the rear brake lines.
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1999 Malibu. 2.4L DOHC Auto
2000 Explorer XLT 4X4 Auto 4.0 SOHC
Old 01-02-2008, 11:01 PM
bikerboy bikerboy is offline
Send a message via AIM to bikerboy
start with the wheel farthest from the master cylinder and work your way towards it. so the order should be RR, LR, RF, LF
Old 01-03-2008, 03:26 AM
G.A.S. G.A.S. is offline
front and rear brakes are seperate systems. if you have not taped into the rears, you will not be required to bleed the rear unless the master has been run out of fluid. In that case. you need to bench bleed the master cylinder and then bleed the whole system using the referance above in sequence.
