4x4 shifting cable wont come out - 96 blazer
Help! I'm trying to get the cable out of my front differential, but it absolutely will not budge! I got it off of the actuator no prob, but and I got the little clip off the diff section, but the cable will not slide out... Should I yank on it?
Re: 4x4 shifting cable wont come out - 96 blazer
Help, it still won't come out... The cable is now hanging from the front differential.
try spraying some wd-40 on it and use wise grips,
though I wouldnt Yank it. Try a twisting motion, while pulling.
1999 Grand Am SS 3.4 OHV
The shaft that the cable goes into wiggles around a little bit. There is also some gear oil leaking out when it wiggles. I'm guessing this is bad?
OK, the fluid has about completely drained out of the front differential. I still haven't gotten the cable out. How difficult is it to replace the selector seal?
The right side half shaft and axle shaft must be removed to replace the shift cable housing seal. The shift cable housing to carrier surface uses silicone sealant, no gasket. There is a special tool required to align the shift mechanism when reassembling.
Is this something a normal shop could do, or should I take it to the dealer? Since the cable is rusted tight in the selector mechanism it snapped flush with the selector! Now I either have to drill out the old cable end somehow, or have the axle taken apart and the entire selector mechanism replaced. What should I do?
It does require special tools that not every shop might have. Check around with local shops to see if they are qualified to do the work.
