Old 12-07-2007, 11:21 PM
g.hampton g.hampton is offline
change oil light
after changing oil I am trying to get change engine oil light to
go out, heard push gas pedal to floor,turn key on and off 3 times.
Old 12-07-2007, 11:43 PM
2000CAYukon 2000CAYukon is offline
Re: change oil light
Turn the key on and pump the gas pedel 3 - 5 times (light will go out) but you have to do it in the first 5 seconds of turning on the key.
//2000CAYukon
Old 12-10-2007, 08:41 PM
cfrank2 cfrank2 is offline
Turn the key to the on position and slowly depress and release the gas pedal within 5 seconds.
Old 12-11-2007, 01:01 PM
J-Ri's Avatar
J-Ri J-Ri is offline
If you have the digital display with the 4-6 buttons either on the steering wheel or on the dash to the right of the steering wheel, you must reset it using the buttons. I just press buttons until I find the "oil life" and then hold the reset button until I get "XXX%". I think it's the button with the picture of the road on it... but I havn't been the oil change guy in a long time.
And if it is the 3x pedal, sometimes you have to do it on the throttle body to get it to work.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
