Old 12-07-2007, 07:53 PM
roessler13 roessler13 is offline
98 Chevy fuel problems
I have replaced fuel pump and pressure regulator. Failing plugs, but holds 60 lbs of fuel pressure. Won't start, getting too much fuel. Every once in awhile, the truck will start and run fine.
Old 12-07-2007, 08:17 PM
tempfixit tempfixit is offline
Re: 98 Chevy fuel problems
Check for codes and post
What engine
Old 12-07-2007, 08:43 PM
No codes, Vortec 350 engine
Old 12-07-2007, 09:28 PM
How many miles??
Have you checked distributor cap and rotor, coil??
Old 12-08-2007, 06:32 AM
I have checked cap, rotors, coil, sensors. I have checked timing.
Old 12-08-2007, 08:44 AM
How many miles on vehicle?
Is distributor rotating?
Have you checked engine coolant temperature sensor
Check ignition moduel in distributor.
Are there any other symptons.
You may need a scanner to help find problem.
Hope this helps
Old 12-08-2007, 09:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
60 lbs of fuel pressure is on the boder line of to low.
You need 65 lbs for injectors to squirt fuel on a cold start.
Check for good hot blue spark to more than one spark plug when no start.
Watch and check cranking fuel pressure on a cold start.
Try a squirt of carb cleaner.
If it is a fuel problem a squirt of carb cleaner will help it start.
Tell us more about the failing plugs?
Do you have the correct good AC delco plugs in it?
MT
