Old 12-07-2007, 11:42 AM
honeydewsparkles honeydewsparkles is offline
2003 Alero Driver window
the driver window won't go down anymore. i got power windows...when i move the button it doesnt even make a sound...is it the motor or maybe a wire got lose or something/
Old 12-07-2007, 07:01 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 2003 Alero Driver window
Check the circuit breaker in the pass side fuse box.
If that is OK then you might try checking the wires to the buttons on the drivers side door. The connector can get corroded and not always make proper connection.
Also try wiggling it side to side, might be something under the button.... If that all fails you might check this link below.
Diagnosing and replacing a power window
1999 Grand Am SS 3.4 OHV
Old 12-29-2007, 06:58 PM
johnsonwingnut johnsonwingnut is offline
I have used the website above and found it helpful. I have two GM products, one a 2001 Alero and found that that connections, either at the switch or the window lift motor can be poor. By pulling the connection apart and applying an "electric grease" type product I was able to have both function again just fine. Have not had any problems with either since. certainly cheaper that a new motor or switch.
The above website I believe shows how to access the switch and motor too!
