Old 12-07-2007, 12:31 PM
eccletia eccletia is offline
1994 Chevy Truck windshield wipers/dashlight/running lights not working
So,
I left my headlights on the other day for about two hours.
I get back to the truck and my dashlights aren't working,
my windshield wipers quit and running lights don't work.
The headlights still work, the turn signals still work, and brake ligths still work.
Any ideas?
I need the fuse box diagram.
Help!
jack
Old 12-07-2007, 06:13 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1994 Chevy Truck windshield wipers/dashlight/running lights not working
Usually if a fuse blows, I check all the fuses. The diagrams can be wrong... excluding a component on a fuse, having it on the wrong fuse. Just connect a test light to ground and probe all the fuses on both sides. If you get a light on one side and not the other, you've found a bad fuse. Sometimes this is actually faster then having the diagram, and you can find a fuse that you didn't even know was bad.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-09-2007, 12:30 AM
1981Cheyenne 1981Cheyenne is offline
I agree with j-ri. check the fuses. one time, i was messin around in my buddy's truck and stuck a screwdriver in his cigarette lighter and his radio, dashlights, wipers all stopped working lol.
not everything has its own circuit. just check em all. you'll know when one is blown
