Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-06-2007, 11:44 PM
redgas redgas is offline
Send a message via Yahoo to redgas
Question my 95 talon esi with a automatic. stuck in second gear
my 95 talon esi with a automatic. stuck in second gear and will not go into 3rd. i put a new solenoid pack on it and did not do any thing does any one know what els it could be i hird it could be a tcu if any one could help me out pls let me know asap ty
Old 12-07-2007, 05:12 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: my 95 talon esi with a automatic. stuck in second gear
Yay subforums. Please use them.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-07-2007, 09:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
So you car works fine up till the time its ready to go into 3rd? You can use park, reverse, 1st, 2nd, but not 3rd? You would try changing the TCU but not sure if that would help the problem or not. Auto trannys are a PITA to troubleshoot, you might just have to end up taking it some where unless you have another TCU you could try.
Has the fluid and filter been changed recently, sometimes that can cause it to do weird things.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-07-2007, 10:11 AM
whene you start it up and start driving it will jam into 2 and stay in to 2 and yep i have changed the fluid and filter
Old 12-07-2007, 10:30 AM
Holset powered 420a
So else works fine untill the tranny gets to second gear and then it sticks. Can you put it in N,P,R after it sticks or do you have to turn the car off before you can do anything else?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-07-2007, 11:51 AM
i have to trun the car off but thene it still does the same thing will start off fine thene jam into second gear and stay into second gear
Old 12-07-2007, 11:58 AM
Holset powered 420a
I would try changing the TCU. Not real sure if thats the problem but its your last option before dropping the tranny.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-07-2007, 03:21 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Pull the TCU, open it up, and look for burn marks. If there are some, you've fried something inside and need a new one. Are you sure it's second gear? It sounds like your car is in limp mode, but then it would have to be stuck in 3rd.
95 Talon TSI AWD
97 Eclipse GST
Old 12-08-2007, 12:49 PM
where is the tcu at on this car??? and im sure its second gear but if it is in limp mode what would i do thane does any one know where the tcu is on this car
Old 12-08-2007, 07:14 PM
Holset powered 420a
It should be right around the ECU under the hood on the right side.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-09-2007, 01:12 AM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
I had a 94' Grand Am that did the exact same thing, it ended up being a sensor for the tranny...
But it was 3rd instead of 2nd.
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
